How To: Install After-Market Head Unit (In Base System)
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
  1. #16
    Senior Member JamminWagon is a Magnum All Star! JamminWagon is a Magnum All Star! JamminWagon is a Magnum All Star! JamminWagon is a Magnum All Star! JamminWagon is a Magnum All Star! JamminWagon is a Magnum All Star!
    Dec 2005
    Cheyenne, WY
    1,219
    To clear things up abit. This post was started back in 2006 before they had NAV mounting kits and the CANBUS adapters. Also my Magnum came with the base stereo system (not Boston Acoustics with the amps). I knew I was going to "upgrade" the stereo so I made sure I didnt have the "premium" system. There are a couple of posts out there that is like mine using the CANBUS adapters. I didnt have the steering wheel controls so I didnt have to bother with that.
    If you have a base stereo or just wanting an IGN controlled tap, this is how you do it.
    BTW, When at car shows, I would reach in through the open window and turn the key to acc then then take the key out. My stereo would play with the key out of the car for 15 min as long as I didnt open a door. This gave me a chance to walk around and check out the other rides without having to leave the keys in the car to demo the A/V system.
    The Vehicle Formally Known As JamminWagon
  3. #17
    Senior Member The_gunslinger's Avatar The_gunslinger is a Magnum Expert in Training! The_gunslinger is a Magnum Expert in Training! The_gunslinger is a Magnum Expert in Training!
    Feb 2011
    Houston TX
    1,421
    Ok... Time to bring an old thread back to life! I'm trying to put an aftermarket head unit in, but it wont turn on. I wired everything up the way it was instructed (power from lighter) and I'm still dead in the water.
    The thing that separates the men from the boys, is how much C4 they have in their toys!
    Try not. Do or do not. There is no try.
    Nerves make you cautious, fear makes you stupid.
    http://www.spacecitylx.com/
    Some people just need a high five... In the face... With a chair.
  4. #18
    Member jd3443pd's Avatar jd3443pd is making a name for themself!
    Sep 2010
    150
    Is the fuse blown for the lighter? Do you have a good ground? Is there a wire that is providing you with a constant 12 volts even when the car is turned off, to keep the memory of you clock and station pre sets? Check power and ground connections with a multimeter and confirm voltage and ground, then start checking for bad connections.
    Diablosport Trinity 93 CAI tune. Volant CAI. Dynomax Ultra Flo custom exhaust sytem. Billet Technologies Oil Catch Can & shifter plate. Drake Strut Tower Brace. 3 G Customz Half Covers & Right Side Cover. AMG Paddle Shifters
  5. #19
    Feb 2011
    Houston TX
    1,421
    Sorry, I actually figured it out. The constannt didn't have power because the new harness was pulling power from a source that was never used. Fuse #37 has something to do with factory nav. I'm assuming that someone needed the fuse for something else and being that I didn't have factory nav, that fuse wasn't needed untill I ran the harness for the new head unit.
  6. #20
    Sep 2010
    150
    Good deal. Glad you got it straightened out.
