Old 08-15-2008, 01:14 PM   #1
11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!
Send a message via MSN to 11secmagnum
Were is the Factory Amp for the mids in a SRT?
Hey dose any one know were the factory amp is for the mids I have the Kicker system and I need to see if the amp is overheating. And also need to know if any one here has upgraded there amp? Im doing the Carputer and trying to figger out how to get audio out of the pc from the soundcard. Any info would be GREAT!
11secmagnum's Sig:Viper Hood 3in Coilovers Powdercoated Wheels EBC Green Stuff pads LED Blue underbody LED Blue Nitrous purge Blue Headlight Strobes 180 T-Stat Predetor programer 150 Wet Shot Cold Fusion Nitrous TCM Tuned Hemi Orange Engine bay Polished A/C lines 3 in Cat-less exhaust Kenwood 8019 Touchscreen Shifter boot Switch Panel Alpine Type R 12 Kicker Mids Valentine One Radar system 25% Tint all around 5% Eyebrow Shaved moldings Shaved Rams head Tinted Tails LC-1 Wideband Digital Nitrous Gauge VDI Doors
11secmagnum is offline   Reply With Quote
Old 08-15-2008, 01:27 PM   #2
~ Vermittler ~
Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!
Im not 100% but I think its up behind the dash on the drivers side...
Karlito's Sig:
~~~~ My CarDomain Page ~~~~
Karlito is offline   Reply With Quote
Old 08-15-2008, 01:38 PM   #3
I will check there, also what do I need to put in a aftermarket amp??
Old 08-15-2008, 01:39 PM   #4
~ Vermittler ~
Are you using the factory head unit? If so, Im really not sure...
Karlito's Sig:
Old 08-15-2008, 01:49 PM   #5
Nope I have the Kenwood 8019, but I do want to do the Carpc system from like VroomPC or somthing like that
Old 08-15-2008, 03:44 PM   #6
4rwheeler's Avatar
4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!4rwheeler is a Magnum Superstar!
It' should be right under the steering column.
Here's the install instructions that I found:
http://www.leeparts.com/pdf/77KICK18AB.pdf
4rwheeler's Sig:
Old 08-15-2008, 04:04 PM   #7
Cool thanks man! Now I just need to find someone that knows what i need to put in a aftermarket amp.
Old 08-15-2008, 07:22 PM   #8
From Silver 2 Sexy Bullet
gstr6800's Avatar
gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!
All you need is a preamp module. For the best results go with 2 4-channel preamps (if you are running all speakers to the amp). These would includ, the dash speakers, front door speakers, rear speakers, and sub. The factor amp is the silver box, located behind the steering wheel, just above the computer adapter.
gstr6800 is offline   Reply With Quote
Old 08-15-2008, 10:04 PM   #9
txnhockey3's Avatar
txnhockey3 is a Magnum Expert in Training!txnhockey3 is a Magnum Expert in Training!txnhockey3 is a Magnum Expert in Training!txnhockey3 is a Magnum Expert in Training!
couple feet of power cable, couple feet of ground, inline fuse, speaker wire, rca patches
txnhockey3 is offline   Reply With Quote
Old 08-16-2008, 08:09 PM   #10
What do I need to buy to put in a aftermarket amp inplace of my factory one for the mids? I have a 4 CH. Planet audio do I need more Ch? were do I buy like a wireing harness to convert my factory wireing over to the new amp?
