Old 02-03-2007, 11:02 PM   #1
Tired of it........
SilverMaggie's Avatar
SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!SilverMaggie is a Magnum Genious!
Send a message via Yahoo to SilverMaggie
Battery Reconnect..
Over in LX Forums, I was reading a post about a battery reconnect procedure, does anyone know what that is? I don't have my manual so i'm not sure if it is in there. I'm asking because I installed an amp today but I have not hooked it all back up yet because i'm waiting on "inspection" from a friend to make sure I did it correctly! I would hate to come this far to mess it all up at the end!
SilverMaggie's Sig:
Originally Posted by Magmania View Post
But please be careful when travelling at those triple digits. You never know, you might hit a pebble or something similar.
SilverMaggie is offline   Reply With Quote
Old 02-04-2007, 09:19 PM   #2
Ms.D-NA
BAM-05's Avatar
BAM-05 is an unknown quantity at this point
Send a message via AIM to BAM-05 Send a message via Yahoo to BAM-05
well SM if I'm understanding u right its where u connect the hot wire to the battery, it is a big (usually the color red) fat wire that give u your power.
BAM-05's Sig:
BAM-05 is offline   Reply With Quote
Old 02-04-2007, 09:22 PM   #3
Ms.D-NA
BAM-05's Avatar
oh yeah, I like ur new picture of the SilverMaggie
BAM-05's Sig:
Old 02-05-2007, 09:43 AM   #4
Here you go..
From the service manual
BATTERY RECONNECTION
Note: This reconnection procedure is to be performed anytime the battery has been disconnected.
1. Connect the battery negative cable (2) to the battery
post and tighten the clamp nut.
2. Install the rear compartment floor trim panel.
CAUTION: Once the battery has been connected,
review and perform the following information as
applicable.
AUTO UP FRONT WINDOW
If the vehicle is equipped with the auto-up front window feature, once the battery is reconnected the door module
needs to be calibrated. The door module requires calibration anytime the battery or door module has been disconnected
for any length of time. To calibrate, perform the following:
1. Connect the battery cables.
2. Using the window switch, raise the window to the full UP position. Hold the switch in position for 1 second, then
drive the window all the way down to the bottom.
ELECTRONIC STABILITY PROGRAM (ESP)
If the vehicle is equipped with ESP, once the battery is reconnected, the Steering Angle Sensor (SAS) needs to be
calibrated. The SAS requires calibration anytime the battery or an ABS (ESP) component has been disconnected for
1. Start the engine.
2. Center the steering wheel.
3. Turn the steering wheel all the way to the left until the internal stop in the steering gear is met, then turn the
wheel all the way to the right until the opposite internal stop in the steering gear is met.
4. Center the steering wheel.
5. Stop the engine.
Old 02-05-2007, 09:52 AM   #5
Ms.D-NA
BAM-05's Avatar
Oh my bad I thought u were talking about the hot wire from the amp to the battery reconnection, sorry
BAM-05's Sig:
Old 02-05-2007, 12:14 PM   #6
Tired of it........
Thank You SoCalRT!
SilverMaggie's Sig:
Old 02-05-2007, 12:17 PM   #7
Tired of it........
Thanx! That was one of the few days it snowed here in the high desert! Does'nt she look pretty in white?!
SilverMaggie's Sig:
