Welcome to the
Custom Magnums forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our
free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. There are no requirements for membership, you don't even have to own a Magnum. Registration is fast, simple and absolutely free so please,
join our community today !
If you have any problems with the registration process or your account login, please contact
contact us .
08-23-2008, 07:06 PM
#1
Anyone have Box specs for JL W7 12"??
Hey guys, I need box Specs for the JL W7 12" I just need to know about the hole size?? I cant get on there web site, I need to know how big of hole to cut for it? I think its like 11 and 5/8 or somthing like that. If anyone has them please post it up. THANKS!
11secmagnum's Sig: Viper Hood 3in Coilovers Powdercoated Wheels EBC Green Stuff pads LED Blue underbody LED Blue Nitrous purge Blue Headlight Strobes 180 T-Stat Predetor programer 150 Wet Shot Cold Fusion Nitrous TCM Tuned Hemi Orange Engine bay Polished A/C lines 3 in Cat-less exhaust Kenwood 8019 Touchscreen Shifter boot Switch Panel Alpine Type R 12 Kicker Mids Valentine One Radar system 25% Tint all around 5% Eyebrow Shaved moldings Shaved Rams head Tinted Tails LC-1 Wideband Digital Nitrous Gauge VDI Doors
08-23-2008, 09:21 PM
#2
B.A.M.M
I have a H.O box with a w612inch ~but its in vegas ~cant get spec til next week~but i found this on the net~its for w7
12" SPL Subwoofer
750Watts RMS
1500Watts Max
3 Ohm
Voice Coil Diameter: 3 Inch
Effective Piston Area: 84.04 SQ.IN.
Xmax: 1.15 Inch
Peak to Peak Mechanical Excursion: >3.3 Inches
Spider Diameter: 9 Inches
Sealed Enclosure Range: 0.75-1.75 Cu.Ft
Ported Enclosure Range: 1.25-2.00 Cu.Ft.
Outside Diameter: 12.5 Inches
Mounting Depth: 9.5 Inches
Priced per speaker
08-23-2008, 09:35 PM
#3
What I need is how big of hole do I need to cut? for it to mount in? is it 11"?
08-23-2008, 09:47 PM
#4
I believe its 11 3/8" but its been a while......
Bigg Boy's Sig: 160DB+ Here I Come
Bigg Boy Customs
www.havocaudio.com
2007 Dodge Magnum SXT (In the works)
*Eclipse Avn7000
*8 6.5" 02 audio mids,8 sound stream tweeters fiber glassed in the front doors (alot more to come)
*Subs?
*Amps? Too Much Power
*3 Kinetik HC2400
*2 runs 1/0 wire all around
*3 Bulk Packs of Dynamat
*Air bagged rear
*250a alt, maybe duals
08-23-2008, 10:35 PM
#5
sweet! do they have templates any place? and how do you cut the holes? whats the easyest way
08-24-2008, 08:14 AM
#6
I would like to say GoMojo has a W7. You might want to PM him.
08-24-2008, 11:32 AM
#7
Thanks guys there site is back up and I got it
08-24-2008, 02:56 PM
#8
easiest way it take a small piece of wood drill a hole in it with a small drill bit, then measure from that hole to the radius of the cut out u want, and drill another hole big enough to get a pencil tip to touch the wood, then go back the first hole and put the drill bit in the hole, and then drill into the wood where u want the hole to be, and then rotate the wood and it will draw a perfect circle...... then cut it out with a router, or jig saw...
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
08-24-2008, 11:26 PM
#9
if you know the volume you need go to this site and start designing it will give you everything you need
RE Enclosure Calculator
08-25-2008, 06:28 PM
#10
that isnt too bad, i have found it to be off every once and a while.....
but its decent to get a good idea.... if u want run the design for me, and I'll check it and make sure there isnt anything thats way off.....
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
Linear Mode
