Old 08-27-2008, 07:06 PM   #1
11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!
Send a message via MSN to 11secmagnum
Question Fiberglass how to....??
Some questions for you fiberglass guys! Im still working on this custom set up for my car, my questoin is this, I have make panels for the side pockets, I have a prebuilt box for my sub and im laying over a 1/2 in plywood on the top to cover it and to mount my amps to in some way not 100% sure yet, but the sub is going to screw to the overlay plywood and then the box is built to the specs I need, then I have a 3/4 in Plywood on the back of the box that butts up to the seats and will be cut out for plexy glass that will say JL on it. So the two side panels will be removible and so will a peice on the bottem. I want to fiberglass everything so all the joints on the wood were I nailed it to eachother is one with no gaps and then I want to paint to match everything to the car. How would I go about fiberglassing that????? I hope what I tryed to explanet makes sence. I hope to get some help on this....
11secmagnum's Sig:Viper Hood 3in Coilovers Powdercoated Wheels EBC Green Stuff pads LED Blue underbody LED Blue Nitrous purge Blue Headlight Strobes 180 T-Stat Predetor programer 150 Wet Shot Cold Fusion Nitrous TCM Tuned Hemi Orange Engine bay Polished A/C lines 3 in Cat-less exhaust Kenwood 8019 Touchscreen Shifter boot Switch Panel Alpine Type R 12 Kicker Mids Valentine One Radar system 25% Tint all around 5% Eyebrow Shaved moldings Shaved Rams head Tinted Tails LC-1 Wideband Digital Nitrous Gauge VDI Doors
11secmagnum is offline   Reply With Quote
Old 08-27-2008, 07:11 PM   #2
Bigg Boy's Avatar
Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!
Send a message via AIM to Bigg Boy
Sounds like what I just did, haha..... I can walk you through it no problem..... All I'm saying is be ready to sand.... painting is alot of work, it all has to be extremely smooth..... i'll pm u my number give me a call, im bored, we can see what we can come up with....
Bigg Boy's Sig:160DB+ Here I Come
Bigg Boy Customs
www.havocaudio.com
2007 Dodge Magnum SXT (In the works)
*Eclipse Avn7000
*8 6.5" 02 audio mids,8 sound stream tweeters fiber glassed in the front doors (alot more to come)
*Subs?
*Amps? Too Much Power
*3 Kinetik HC2400
*2 runs 1/0 wire all around
*3 Bulk Packs of Dynamat
*Air bagged rear
*250a alt, maybe duals
Bigg Boy is offline   Reply With Quote
Old 08-27-2008, 08:13 PM   #3
Cool Man, Thanks for your time!! you helped me out alot!!!
Old 08-27-2008, 08:55 PM   #4
Bigg Boy's Avatar
Not a problem, my pleasure.
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
