Old 09-27-2008, 08:43 AM   #1
Magnesium SXT
bayshorspts's Avatar
bayshorspts is making a name for themself!
Aftermarket Radio Install
what pac-audio piece would i need to instal an aftermarket headunit into my 05 SXT with the Boston system?
Thanks in advance for help
bayshorspts's Sig:
bayshorspts is offline   Reply With Quote
Old 09-27-2008, 08:51 AM   #2
jerkdogg's Avatar
jerkdogg is a Magnum Expert!jerkdogg is a Magnum Expert!jerkdogg is a Magnum Expert!jerkdogg is a Magnum Expert!jerkdogg is a Magnum Expert!
I dont know whatz the harness model# but from my understanding it cost more BCUZ of the BOSTON setup U have!!!!!
jerkdogg is offline   Reply With Quote
Old 09-27-2008, 04:00 PM   #3
MOPAR SHOW OFF 09'
Bay Area Magnum's Avatar
Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!Bay Area Magnum is a Magnum Genious!
Send a message via AIM to Bay Area Magnum Send a message via Yahoo to Bay Area Magnum
Id pull all that Boston stuff out and build a real system !
Bay Area Magnum's Sig:
Donations Now being accepted for Kids Beating Cancer send paypal to moparshowoff@yahoo.com
Bay Area Magnum is offline   Reply With Quote
Old 09-27-2008, 06:24 PM   #4
Magnesium SXT
im poor so that aint happening
bayshorspts's Sig:
Old 09-27-2008, 06:27 PM   #5
jayalbertcars's Avatar
hello i have the amp by pass wiring if you need it for the boston system
Old 09-29-2008, 09:24 AM   #6
magnumPI is an unknown quantity at this point
How exactly does that work? In my Mustang all I did was leave the wires that were going to the factory amp unpluged(cut) and used the speaker wires only. This way i was able to use the speakers and use an after market H.U. I really don't want to use the stock H.U. and have to tap into the speakers and use the hi output connections instead of the rca output on my amp. Do you think this is possible on the Mag?
magnumPI is offline   Reply With Quote
Old 10-04-2008, 06:58 AM   #7
shakenbaked83 is an unknown quantity at this point
Send a message via AIM to shakenbaked83
Aftermarket Navy Install
I have the same problem in my Magnum RT. I got a PAC I think and also another harness that sends info from the steering wheel to the Navy (AVICD2). Every once and a while they trip off and all I hear is my subs. SO, I have to pull my bezel out and dis- and re- connect both harnesses until the audio cuts back in. It's a real pain and I'd like to know how to fix it as well. Anyone have any ideas?
shakenbaked83's Sig:it's not miles per gallon, it's smiles per gallon...
shakenbaked83 is offline   Reply With Quote
Old 10-04-2008, 07:00 AM   #8
ps, If you bypass the amp you can't use the amp (me thinks).
Old 10-08-2008, 09:21 AM   #9
Well I used a PAC and tapped into the L rear speaker the two negs to neg and the two pos to the pos of course and hooked my rca cables from my after market sub amp and voila! no problems
Old 10-10-2008, 08:27 AM   #10
moonstreaker's Avatar
moonstreaker is just warmin' up!
Go with the Metra CHTO-01. Unlike the PAC products the Metra has 4 preamps, which allows you to keep the ability to fade.
moonstreaker's Sig:Founder of DVMMC
Moonstreaker on Cardomain.com
Brilliant Black 2006 Magnum R/T RWD
-black LED tails, MSRT headlamps, aFe stage II, DS Predator, 180* tstat, 22Elite console cover w/custom embroidery by Jina's Sew Simple, Bassani SS exhaust, Black Chrome MSRT wheels, Danko chin spoiler, Pioneer AVIC F90BT
-1st Place '05+ Magnum Class Carlisle 2008
-Celebrity Pick Carlise 2008
moonstreaker is offline   Reply With Quote
