Old 10-05-2008, 11:43 PM   #11
Originally Posted by Bigg Boy View Post
Where did you guys run your power wires through the fire wall.... I'm trying to see where I can do 3-4 more runs of 1/0 pics would be great....
I would run it right next to the stock wire... it will be your best bet to have a clean trail to the back of the ride.......
Old 10-05-2008, 11:44 PM   #12
Danger,Death,Destruction
V8Mag's Avatar
V8Mag is gettin' serious now!V8Mag is gettin' serious now!V8Mag is gettin' serious now!
Send a message via MSN to V8Mag
If needed you could drill your own hole, and place a grommet there and run the wire through that, but I'm not a fan of cutting into the firewall
V8Mag's Sig:
TEAM W.A.R.
Paving the roads, one burnout at a time...
Danger, Death, Destruction
2005 Dodge Magnum R/T, 2000 Jeep Grand Cherokee Laredo,
1970 Monte Carlo SS 454, 2008 Honda CBR600RR
Mods: JBA Shorty Headers/Cat-back, HHP Mid Pipe, Smoked Headlight Covers, VDI Kit, X-Large Eye-Lids, DMH Low Profile Electric Cutouts
Pending: 22" Rims
V8Mag is offline   Reply With Quote
Old 10-06-2008, 12:04 AM   #13
Originally Posted by gstr6800 View Post
I have a 1/0, 4, and 8ga setup. From the battery, I have 1/0 through a t-block (to splice in with the main power cable) around the spare tire well to a dual fuse block. One fuse is dedicated for my cap, and the other is dedicated to a distribution block to power my amps. From that fuse block, I am using 4ga to the cap and 4ga to the power distribution block. My power cables at the amps are 8ga cables and the grounds are 4ga setups. A larger ground will allow for a better flow of clean power for better amp performance. At the ground distribution point, my 4ga wires merge to a short 1/0ga wire. Here is a diagram of what I have put together for my system:
Hope this helps dude.
hope you know that is a dangerous way to hook up your goodies for some reference check out this site Basic Car Audio Electronics number 14 is all about fuses when to use and what size to use.........
Old 10-06-2008, 03:00 AM   #14
From Silver 2 Sexy Bullet
gstr6800's Avatar
gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!
^^^ What you don't see in the diagram is that the power distribution block is fused. Each amp is fused on the amp as well. For all of my setups, I keep the gains turned no further than halfway up to prevent overheating and clipping. I used ground cables larger than my power cables in order to better power distribution and circuit protection. Car audio has been my thing for years, and my background consisted of circuit board repair before boards were so cheap to buy, so I got this power and grounding on lock. I think I am telling on myself about how old I am. LOL. My system now is not as big as other systems I have had in the past, so I am not concerned with hot wires and run foul-ups, line noise, and overworked amps. Thank God I have learned with the times. With this setup, I am pushing under 2400W. I have an 4CH 800W amp for hi/low outputs, and two 2CH 800W amps running on each coil for a stable 2 ohm load per amp. So far, so good. I can drive from Atlanta to Dallas and the amps never overheat once. Gotta love it.
gstr6800's Sig:
-Obama Sponsor and Proud American-
SSCLX Club - www.southernstylecruiserslx.com
My Car Domain - http://cardomain.com/ride/2527110
Street Dreams Photos - http://www.streetdreams.org/photo/sh...o=2898&cat=509
Train Horn Test - http://www.youtube.com/watch?v=VgGLn01G7ok
gstr6800 is offline   Reply With Quote
Old 10-06-2008, 08:36 AM   #15
Cool deal just dont want to see anyone blow there stuff or have there ride catch on fire ... anyone unsure about hooking up electrical you should check out the link above it has a lot of great info.........
Old 10-06-2008, 10:50 AM   #16
gstr6800's Avatar
^^ It is funny that you mention that. I was racing down I-20 in my Dodge Intrepid on dubs against a roommate of mine in an Ack Integra. (Even then, Dodge had a V6 that was putting them down.) Well, to make a long story short, I saw him slow down and pull over against the median wall, so I slowed down. I pulled off and backed up on to find that his car was full of smoke. Lo and behold, his audio setup caught on fire. LOL. Imagine that. The moral to this story is that it is good to learn from other people's mistake.
Note: I forgot to mention that I only use oxygen-free cable. You can't start a fire if there is no air.
gstr6800's Sig:
Old 10-06-2008, 11:36 AM   #17
Ouch that had to hurt.... nothing like hot boxing burnt electronics
Old 10-06-2008, 11:46 AM   #18
MrCapcom's Avatar
MrCapcom is gettin' serious now!MrCapcom is gettin' serious now!
Send a message via AIM to MrCapcom Send a message via MSN to MrCapcom Send a message via Yahoo to MrCapcom
How I Got Into My Cabin And Wired My Switch
I dunno if thats gonna help but thats what im gonna use tonite when i wire my ccfl's to my grill
MrCapcom's Sig:
My Basic Magnum CarDomain Page
CCT White Mod[Done!] Tints [Done!] Whats Next PM Suggestions! So far I wanna VHT my Rears
MrCapcom is offline   Reply With Quote
Old 10-07-2008, 07:12 AM   #19
bighurb's Avatar
bighurb is a Magnum Expert!bighurb is a Magnum Expert!bighurb is a Magnum Expert!bighurb is a Magnum Expert!bighurb is a Magnum Expert!
Where can I get that at.
bighurb's Sig: Da Blue Lagoon
stay below the radar at all times
bighurb is online now   Reply With Quote
Old 10-07-2008, 08:41 AM   #20
oxygen-free cable in no way will stop fires oxygen-free is saying the copper itself has no oxygen making it less susceptible to corrosion... Most fires will start because the wire itself gets so hot it melts the outside covering, the wire then becomes exposed to whatever is around and if its flammable material then you have a fire....
