Old 10-04-2008, 11:53 PM   #1
Bigg Boy's Avatar
Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!
Send a message via AIM to Bigg Boy
alt to batt home runs
Where did you guys run your power wires through the fire wall.... I'm trying to see where I can do 3-4 more runs of 1/0 pics would be great....
Bigg Boy's Sig:
Bigg Boy Customs
www.havocaudio.com
2007 Dodge Magnum SXT (In the works)
*Eclipse Avn7000
*8 6.5" 02 audio mids,8 sound stream tweeters fiber glassed in the front doors (alot more to come)
*Subs?
*Amps? Too Much Power
*3 Kinetik HC2400
*2 runs 1/0 wire all around
*3 Bulk Packs of Dynamat
*Air bagged rear
*250a alt, maybe duals
Bigg Boy is offline   Reply With Quote
Old 10-05-2008, 10:08 AM   #2
lvmagnumrt's Avatar
lvmagnumrt is a Magnum All Star!lvmagnumrt is a Magnum All Star!lvmagnumrt is a Magnum All Star!lvmagnumrt is a Magnum All Star!lvmagnumrt is a Magnum All Star!lvmagnumrt is a Magnum All Star!
why not just run from the battery that is already located in the rear? just a thought!
lvmagnumrt's Sig:
2006 R/T Brilliant Black Metallic Pearl...K&N Cold Air Intake(63 series), VHT Tinted Tailights and Third Brake Light, GTS Headlight Covers and In-Channel Window Visors, Red R/T badge, Interceptor Badges, Body Color Matched Front Grills and Foglight Bezels, Polished Pistol-Grip Shifter, Shaved Side Moldings, Jensen 8.5" Overhead DVD Player, Chrysler Wing, Wood Flooring Kit in Rear, Dual Flowmaster Super 40's, Black Chrome Tips
lvmagnumrt is offline   Reply With Quote
Old 10-05-2008, 12:26 PM   #3
Bigg Boy's Avatar
I'm gonna have ~500a of alts........ I'm gonna melt the stock wires if I try to use it.....
Bigg Boy's Sig:
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
Old 10-05-2008, 02:04 PM   #4
From Silver 2 Sexy Bullet
gstr6800's Avatar
gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!gstr6800 is a Magnum All Star!
I have a 1/0, 4, and 8ga setup. From the battery, I have 1/0 through a t-block (to splice in with the main power cable) around the spare tire well to a dual fuse block. One fuse is dedicated for my cap, and the other is dedicated to a distribution block to power my amps. From that fuse block, I am using 4ga to the cap and 4ga to the power distribution block. My power cables at the amps are 8ga cables and the grounds are 4ga setups. A larger ground will allow for a better flow of clean power for better amp performance. At the ground distribution point, my 4ga wires merge to a short 1/0ga wire. Here is a diagram of what I have put together for my system:
Hope this helps dude.
gstr6800's Sig:
-Obama Sponsor and Proud American-
SSCLX Club - www.southernstylecruiserslx.com
My Car Domain - http://cardomain.com/ride/2527110
Street Dreams Photos - http://www.streetdreams.org/photo/sh...o=2898&cat=509
Train Horn Test - http://www.youtube.com/watch?v=VgGLn01G7ok
gstr6800 is offline   Reply With Quote
Old 10-05-2008, 02:57 PM   #5
Bigg Boy's Avatar
Thanks for the diagram... But that type of step up wont support what I'm gonna be running.....
I'm just wondering where you guys ran your 1/0 wire though the firewall?
Bigg Boy's Sig:
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
Old 10-05-2008, 03:11 PM   #6
gstr6800's Avatar
If your battery is in the back of the car like mine, you don't need to run it through the firewall. Most of the wiring should be done in close proximity. If you are running your connection from under the hood, follow the skirt line to the back. From there, you should be able to punch a hole under the rear seat (preferrably where the seat folds and run it back from there. If you run it along the passenger side of the car and into the cab at that hole, you can follow the cable tray if you are placing you amps in the spare tire well, or you can pop a hole in the tray and mount your components there.
gstr6800's Sig:
Old 10-05-2008, 03:47 PM   #7
Bigg Boy's Avatar
You do need to run wires from the front to back if you have an upgraded alt or dual alts like im gonna be running.... the stock electrical did not intend for a 10,000w rms stereo system to be installed....
Bigg Boy's Sig:
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
Old 10-05-2008, 04:11 PM   #8
gstr6800's Avatar
Yeah, I see what you mean. Have you ever looked into capcells? Extra batteries and caps are good, but capcells may help you out wih that much power and a major alt upgrade. Have you thought about looking into limo or RV alts or Stinger audio alts? Instead of running two, you may be able to use one HO alt.
gstr6800's Sig:
Old 10-05-2008, 05:14 PM   #9
bighurb's Avatar
bighurb is a Magnum Expert!bighurb is a Magnum Expert!bighurb is a Magnum Expert!bighurb is a Magnum Expert!bighurb is a Magnum Expert!
Tring to load the pics off my phone. But pop your hood look on top of the fire wall on the driver side pop the cover off and look beside the brake booster and you will see the rubber groument with wires already comming out of it. Pull it out and there you go. It's enough play in the wires for you to pull it towards the engine bay. Will post pics as soon as I can.
bighurb's Sig: Da Blue Lagoon
stay below the radar at all times
bighurb is online now   Reply With Quote
Old 10-05-2008, 10:34 PM   #10
gstr6800's Avatar
^^ I know what you are talking about Big H. I wouldn't pop it out, unless you are trying to pop a hole in it and use it like a grommet. If you remove it and run the wire through, you may cause a little rubbing and eventually, cause a short.
gstr6800's Sig:
