Old 11-19-2008, 07:59 PM   #1
cavy68 is just warmin' up!
before i break something question!
2005 2.7, want replace factory stereo with another since mine crapped out on me, how do you remove the damn thing?? be nice i am not a mechanical know all. any help would be great.
cavy68 is offline   Reply With Quote
Old 11-19-2008, 08:18 PM   #2
~ Vermittler ~
Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!Karlito is the one everyone should be listening to!
The bezel just pops out, start down by the ash tray and work your way up, you may need to disconnect the hazard/pass air bag light/rear wiper controls. After the bezel is removed it's just a matter of removing 4 screws and disconnecting the wire harness & antenna from the head unit.
Karlito's Sig:
~~~~ My CarDomain Page ~~~~
Karlito is offline   Reply With Quote
Old 11-19-2008, 08:38 PM   #3
---magnum minded---
GreenKing's Avatar
GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!
Send a message via MSN to GreenKing
you WILL have to remove the harness for the hazard button strip. You can get it out one of two ways, like karl said pop open the ash trey and there is enough of a lip there to start putting a little outward pressure on. OR you can tip the upper vents up, reach in there and start at the top. They are not strong clips holding it in, so it should be fairly easy to remove. Radio removal is obvious once you get the bezel out
GreenKing's Sig:
"Respect for religion must be reestablished. Public debt should be reduced. The arrogance of public officials must be curtailed. Assistance to foreign lands must be stopped or we shall bankrupt ourselves. The people should be forced to work and not depend on government for subsistence." - Cicero, 60 B.C.
GreenKing is offline   Reply With Quote
