ok im almost done, i just need one last thing, i noticed on the cables connecting fron the car to the deck(the cables you have to connect color to color) that there are two black and two yello cables on the side coming from the car and omn the deck there is only one black and one yellow, should i connect all three black together and all three yellow?
You can if you want. Or you can just use one yellow and one black and tape off the others. You still have to find your switch power which can be found on your cig lighter in the ash tray. You just have to move the correct fuse for that line to switched (if it isn't already). Good luck. Also, if your headunit has a dimmer/illumination line, you can tap the line used to dim the esp/hazard buttons...that's what I did.
x2, I would use caps over tape but thats what I would do.
