#11 |
Did You Tap In From Behind The Deck Or From The Back Cargo Area, So Is There A Total Of 4 Wires On The Inline Conv That You Tap Into Both The Pos And Neg Of Each Speaker And Then Plug In Your Rca's Right, OH AND WHERE DID YOU RUN YOUR REMOTE WIRE FROM
#12 |
Yup, 4 wires as you described....you can tap in at the rears OR up at the deck depending which head unit you have, if you have the premium sound system there is an amp under the steering column that you would need to tap off of. Go here: Crutchfield: Car Audio, Plasma & LCD TV, Home Theater Systems, GPS
These guys have everything you'll need at a good price, plus they have excellent customer service and can tell you which wires to tap for the remote turn ons and even tell you how to pull the car apart! I'll be doing the same as I have yet to tear into mine to do the audio. Also, search the threads here and at lxforums.com (there is a TON of info over there) |
