Old 02-14-2008, 01:17 PM   #1
keno814's Avatar
keno814 is an unknown quantity at this point
Stereo HELP!!!!!!
my sysytem started sounding like crap the other day and don't no why. I have 2 12" kenwood subs with a 800 watt kenwood amp hooked up to the factory head unit. I have a line converter hooked up to the rear left speaker but only one rca plug works is that cause it's hooked to one speaker? my amp has a plug to do without converter but not exactly sure how to hook that up. was going to invest in a cap but not sure if that's what i should do. would just upgrading the battery and ground wire help a lot? it sounded so good when first hooked up but now does seem to hit like it did. any help please.
keno814 is offline   Reply With Quote
Old 02-14-2008, 06:01 PM   #2
bob102386's Avatar
bob102386 is just warmin' up!
sounds like the converter is messed up. I wouldnt say battery problem
bob102386 is offline   Reply With Quote
Old 02-14-2008, 06:30 PM   #3
Evaluating...
MagWag's Avatar
wouldnt hurt to beef up the wires a bit n e ways!
MagWag's Sig:MEMBERS MAP!
www.myspace.com/thompstud
No, No, NO DRAMA!
MagWag is online now   Reply With Quote
Old 02-14-2008, 07:02 PM   #4
JamminWagon's Avatar
JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!
Yeppers. Also, some music only have bass on one side, listen to some of the first Van Halen cds and you will hear the bass on one side. If you tap on the left speaker and the bass in mixed to the right, you will be losing out.
Look in the amp manual it should tell you what leads go to what speakers(L/R & +/-). You just tap into the speaker wiring and run the lead to the "Speaker Level" input to the amp. The only drawback to this is that the HU can overdrive the built in converter. This can also happen to the cheap charlie converters that can be bought at the generic stores. There are some good ones out there with leds that show overdriven and have adjustments to limit the ovedrive.
Also if you have the BA system, the rear speakers are crossed-overed to take some of the bass out. Since they dont have enclosures, bass can ruin them easily. The doors are the bass producers in the BA systems, they are crossed over as a low pass. These are the ones you want to tap off of.
If you have the plain jane 4 speaker system, then all the speakers are full range and it dont matter which ones you tap off.
JamminWagon's Sig:
