Old 02-20-2008, 06:26 PM   #1
Bouch is making a name for themself!
power suppy for dvd screens?
I have recently installed a kenwood dvd deck in my car and iam going to but a 19" Lcd monitor in the back, with an xbox. i would like to know if yhou guys are just using power invertors and are also adding an extra battery(deep cycle) to help with the power/. what have you guys done I would love to know?
Bouch's Sig:
Bouch is offline   Reply With Quote
Old 02-20-2008, 07:04 PM   #2
Rickeyboi is making a name for themself!
For the over head you should be able to drop a constant hot or switch hot from the radio harness. You dont need a extra battery for running the power inverter but make sure that your have a big enough inverter to run the xbox...good luck and post plenty of pics of the work.
Rickeyboi's Sig:
Rickeyboi is offline   Reply With Quote
Old 02-20-2008, 07:30 PM   #3
no the deck is all good running but i got to power a 19"lcd and an xbox dont know yet how
Bouch's Sig:
Old 02-21-2008, 03:26 PM   #4
oh my bad...like I said...you dont need another battery...all you need is a power inverter that can handle the screen and xbox...something around 400 watts or more would be good.
Rickeyboi's Sig:
Old 02-22-2008, 11:47 PM   #5
well the screen draws 1 amp while running and a max of 30 amps on start up but the xbox i have no idea
Bouch's Sig:
Old 02-23-2008, 05:22 AM   #6
Respect My Authoritah!
lowriderman3's Avatar
lowriderman3 is a Magnum All Star!lowriderman3 is a Magnum All Star!lowriderman3 is a Magnum All Star!lowriderman3 is a Magnum All Star!lowriderman3 is a Magnum All Star!lowriderman3 is a Magnum All Star!lowriderman3 is a Magnum All Star!
Just make sure to get an inverter to handle the wattage output and you will be good as mentioned. I have a 21" TV on an inverter with no problems.
lowriderman3's Sig:
Check Out My Car Domain Page
lowriderman3 is offline   Reply With Quote
