Old 02-23-2008, 08:40 PM   #1
djjim1's Avatar
djjim1 is gettin' serious now!djjim1 is gettin' serious now!djjim1 is gettin' serious now!
Send a message via MSN to djjim1
Cool First time need help
I need to know what goes wher on the crossover...
the cable from the speekers, I know where to plug it, but the RCA cable got me confuise and for now im using my stock radio so how many RCA cables come out from it?
Take a look at the pictures see if it helps....please
thecrossover.jpg - Image - Photobucket - Video and Image Hosting
mimusicaconlosnombres.jpg - Image - Photobucket - Video and Image Hosting
djjim1's Sig:
djjim1 is offline   Reply With Quote
Old 02-23-2008, 08:57 PM   #2
the stock head unit doesnt have RCA usually you need to get a LOC as for how to hook everything up depends on
1) how many amps your using
2) how many channels the crossover has
if your just adding subs you can us a LOC (Line Output Converter) in the back going into your crossover rear input from said crossover you would use the low or sub output to go to your amp and of course your subs would be connected to the amp............
Old 02-23-2008, 11:20 PM   #3
djjim1's Avatar
im using 3 amps i had it like that in my last car exept the radio but some body did it for me 2 amp for sub and one for the doors speekers an tweeter
djjim1's Sig:
Old 02-24-2008, 03:49 PM   #4
problem with your crossover it has three inputs and three outputs this is great if you have three outputs coming from your head unit but unless you have an after market head unit you dont ...you can splice of the front with a LOC and off the rear with another LOC this will keep front and rear fading. since your sub is in the back i would use Y RCA connectors from your rear LOC to the rear and sub inputs on the crossover and from your front LOC to the front inputs on the crossover you will need rca coming from the outputs to your crossover to the inputs of your amps...this should work fine
just remember an electronic crossover will go before your amp it changes the frequency so the amp is only amplifying the desired frequency for said amp
the passive crossover goes before the speaker it changes the frequency of the signal coming from the amp
if you have some time peak around on this site there is allot of info that might help you fully understand
Basic Car Audio Electronics
hope i didnt miss anything and hope this helps
