As Anyone Done Thefront Dash Speakers
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
    Member MAGRIDER's Avatar MAGRIDER is an unknown quantity at this point
    Feb 2008
    Salt Lake City
    94
    Question As Anyone Done Thefront Dash Speakers
    AS ANYONE DONE THE FRONT DASH SPEAKERS OR GOT PICS ON HOW TO DO IT IM REALLY WANTING TO ADD SOME AND DO GUYS KNOW THE BEST SIZE TO GO WITH ANY INPUT WOULD REALLY HELP ME THANX
    Remember Hookers Love Cupcakes krewkut125's Avatar krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious! krewkut125 is a Magnum Genious!
    Sep 2007
    Palm Bay, Florida
    4,145
    Talk to Bigal, I think he has done this. And if not he might do it now! lol.
    Respect My Authoritah! lowriderman3's Avatar
    lowriderman3 is a Magnum All Star! lowriderman3 is a Magnum All Star! lowriderman3 is a Magnum All Star! lowriderman3 is a Magnum All Star! lowriderman3 is a Magnum All Star! lowriderman3 is a Magnum All Star! lowriderman3 is a Magnum All Star!
    Jul 2006
    South GA
    2,872
    Mine have been replaced to include all of my interior ones, but my stereo guy did mine.
    Member Bouch is making a name for themself!
    Jul 2007
    Edmonton, Alberta
    59
    INSTRUMENT PANEL SIDE SPEAKER
    NOTE: A battery reconnect procedure must be performed anytime the battery has been disconnected. (Refer to 8 - ELECTRICAL/BATTERY SYSTEM - STANDARD PROCEDURE).
    1. Disconnect and isolate the battery negative cable.
    2. Remove speaker cover from instrument panel.
    3. Remove mounting fasteners.
    4. Disconnect electrical harness connector and remove speaker.
    INSTRUMENT PANEL CENTER SPEAKER
    Member Nate Dawg is an unknown quantity at this point
    Jan 2008
    North Carolina
    70
    hey that is a great schematic! Thanks for addin that to your post.
    Nate Dawg From NC
  7. #6
    QUE TU SABE DESO TRUEST ONE's Avatar TRUEST ONE is a Magnum All Star! TRUEST ONE is a Magnum All Star! TRUEST ONE is a Magnum All Star! TRUEST ONE is a Magnum All Star! TRUEST ONE is a Magnum All Star! TRUEST ONE is a Magnum All Star!
    Jun 2007
    Maryland
    1,435
    I'm not sure if you can fit anything other than a 3 1/2 inch. speaker in that opening. Hmmmm.....let the modding begin!!!!
  8. #7
    One wicked azz car! Bigal470's Avatar
    Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to! Bigal470 is the one everyone should be listening to!
    Oct 2006
    Oceanside, CA
    5,940
    fyi ^^^ that diagram is of the 300c much more involved in the mag
    the dash takes 3.5 inch speakers
    here is a quick step by step
    1)remove a pillar covers - be careful doing this once the top pops out it has a little clip you need to remove from behind if you pull to hard you will break it
    2)remove heat defuser - this is the long plastic thing along the window its held on by the same snap clips as everything else on the dash once you have it off make sure all the clips are on the defuser before you put it back on it will make it easier to install and help make sure you dont have any rattles
    3)run wire to stereo - with the top of the dash off and the stereo out this is easy you can also remove the under dash covers to make it even easier.
    4)connect + & - wires to the speaker
    5)install speaker - they usually only take two screws
    6)splice wires into front speaker leads - do a search for the wiring diagram dont have it handy
    7) \re install your stereo and crank up the tunes
  9. #8
    120+ on the 14 FRWY!!!!!! Braddah Jay's Avatar Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar! Braddah Jay is a Magnum Superstar!
    Apr 2007
    Driving the SRT life in Palmdale,Cali
    1,238
    I put a 4" mid in mine with the help of a dremel tool. I have JL Audio 3-way component set for the front. I'll try to dig up some pics........
  10. #9
    Feb 2008
    Salt Lake City
    94
    Hey Thanx Guys A Lot Of Good Input I Love Pics But I Think I Can Figure It Out But Thanx Again
  11. #10
    Junior Member vmax-boy is an unknown quantity at this point
    Aug 2008
    18
    more dash speaker questions
    I have the 6-speaker Boston acoustics system and it appears the amp is integrated into the 6-CD changer head unit (which is a bummer since I wanted to add a pre-amp equalizer while still using the stock head unit, but now can't).
    Anyway, I wanted to add a pair of tweeters, but have no idea which wires coming from the back of the head unit are the dash speakers (which is where I'd tap in).
    Does anyone know if the dash speaker wires come from the large connector or the small one that's next to it, and what the colors are for right and left positive and negative?
    Thanks a million,
    Chris
  12. #11
    A huge Cavs fan mjgmagnum's Avatar mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious! mjgmagnum is a Magnum Genious!
    Oct 2007
    Lorain, OH
    3,065
    Blog Entries
    1
    any how to on removing just the top of the dash
  13. #12
    Oct 2007
    Lorain, OH
    3,065
    Blog Entries
    1
    I am having trouble getting very frustrated on how to run the speaker wire. How do i get it upto the dash locations????? I tried feeding it down them I tried feeding up from behind the radio and Im not having good luck
  14. #13
    Oct 2007
    Lorain, OH
    3,065
    Blog Entries
    1
    bump for help really want to do this today.
  15. #14
    Oct 2007
    Lorain, OH
    3,065
    Blog Entries
    1
    Well I was able to run the wires without help, I used a metal coat hanger and tied speaker wire to it and ran it right up to the holes took about 10 min. Im so glad I did it
  16. #15
    Gettin' ¢ ™ ronald_smail's Avatar
    ronald_smail is a Magnum Expert! ronald_smail is a Magnum Expert! ronald_smail is a Magnum Expert! ronald_smail is a Magnum Expert! ronald_smail is a Magnum Expert!
    May 2009
    San Antonio, TX
    944
    Nice going, vmax-boy, I have the boston acoustics system, but it may be different from yours, as I dont have a 6-CD changer with my system. The way my system works is that I believe it has +&- wires going to the back of the head unit and a few others for Front left, Front right, Rear left and rear right. Then those wires lead into the factory amp which I have come across in my modding days and that is under the steering wheel, behind the plastic knee guard and then behind a metal guard sits the factory amp. If I were to install tweeters, it'd be from there, but again, our set up is probably really different if you have the 6 CD changer
