Old 03-19-2008, 06:46 PM   #1
eurojet is an unknown quantity at this point
Question if this part is actually needed
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
item number 330198877098
I have installed many aftermarket decks in many cars since this is my first Dodge, was wondering if this device which says it retains the factory Can-Bus is actually needed?. What would not work if i did not use this?
Sorry about not having the direct link to the item
thanks
Shawn
eurojet is offline   Reply With Quote
Old 03-19-2008, 07:21 PM   #2
If you want to plug and play a new deck into the factory wiring you will need the canbus harness. I'm sure you could get a wiring diagram and cut and splice a ton of wires but most folks use the adapters
