Hi guys
Any comments on the JL Audio VR690-CXI 6x9's or the VR650-CSI component systems. Second, you SE guys & gals, (non nav) what wire harness kits did you use if you replaced the head unit. The local shop is trying to sell me a kit near $100 bucks, I would think that that might be the Boston system or nav system harness. Thanks Cessnafixer |
bullSh!t on the 100 buck harness i got mine for under 20 at fry's electronics you can also get them at automotive stores (pep boys, kragon) they are trying to sell you something you dont need...
as for the JL Audio the VR series they are nice what you listed will work perfect 650 in the door up front and the 690 in the back. I have an SE and i use TR650 in the door ![]() the TR350 in the dash ![]() in the back i have the same setup ![]() the one inch tweeters that come with the TR650 I have mounted in the A and D pilers I dont have any shots give me a minute i will go take some |
hello we put a unit in a 300 it had the boston set up the amp by pass wiring was 100.00 Guam had got it to be on the safe side we needeed it there is a lot of wiring in this kit pm me and i can send you 6 foot pieces with the wiring diagram the unit wiring was around 25.00
when i put in my tv/dvd i was told that the wiring harness i was gonna need was $100, i told them BS. that is only for the 2007 & up models. i have a 2006. so if your not under a year old, u wont need it. DONT LET THEM LIE TO YOU
Hi again
Thanks BigAL great pics. Bellow is the explination the stereo shop said I should purchase the $100 harness. You do you think. is this true As for the harness, its still saying that you need this one, reason being it retains accesory power. You could use the regular harness and get accesory from elsewhere. That harness is $15 bucks Cessnafixer |
you can get acc power from the cig lighter so why spend 85 more dollers for that option...I would never go back to that shop...
