Old 03-28-2008, 10:32 PM   #1
06Mag is an unknown quantity at this point
Rear View Mirror Vibrating
Is there a way to stop the rear view mirror from vibrating down to where I'm looking at my lap? Is there a way to tighten it? I was thinking of setting it in the the car, then pulling it out and adding JB Weld around the adjustment points to keep it from sagging down after a few minutes of Bumping my system. I'm only running 2 12 inch Kicker Comps with an old school Rockford 401s amp. I've never had a rear view mirror sag down the way this one does, they usually just vibrate to where you can't see out of them. Any suggestions would be appriciated, seeing some systems on this site makes me wonder if anybody else has this problem. I did add 2 layers of Dynamat to the rear of the hatch and 1 layer to the top if that helps any.
06Mag is offline   Reply With Quote
Old 03-29-2008, 12:29 PM   #2
bigdunndizzle is making a name for themself!bigdunndizzle is making a name for themself!
Send a message via AIM to bigdunndizzle
i have the same problem. i just quit using it and use the sidemirrors now. any advice would be nice though
bigdunndizzle's Sig:My ride on cardomain
http://www.cardomain.com/ride/3032810
bigdunndizzle is offline   Reply With Quote
Old 03-29-2008, 02:57 PM   #3
Asian Persuasion
Magmania's Avatar
Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!
I believe there is an allen set screw. Just tighten it up.
Yep, I just went out and confirmed it. Right at the bottom of the mount.
Magmania's Sig:
Old 03-29-2008, 03:04 PM   #4
MagnumRT05's Avatar
MagnumRT05 is just warmin' up!
Send a message via AIM to MagnumRT05
Kicker Comps huh...
Use glue?
MagnumRT05's Sig:Richie
Mods
-Slammed - UAS
-Turbo - CIS
-392ci Stroker w/ Crower Cam/Rods - Inertia
MagnumRT05 is offline   Reply With Quote
