Old 04-07-2008, 01:13 PM   #1
unkone is an unknown quantity at this point
Speaker Whine
Just got done replacing my rear 6x9's, and I notice there is an low whine coming from them when the music is off. I grounded the amp to the battery ground. Is this a good idea? Where are you guys grounding your amps to?
It could be my rca's to I am not sure if they are correctly shielded.
unkone is offline   Reply With Quote
Old 04-07-2008, 01:16 PM   #2
rob619's Avatar
rob619 is gettin' serious now!rob619 is gettin' serious now!rob619 is gettin' serious now!
how long is your ground wire? also i would check the rca's.. one of mine broke at the tip and i got the whining noise till i replaced it
rob619 is offline   Reply With Quote
Old 04-07-2008, 02:11 PM   #3
Jaymag's Avatar
Jaymag is making a name for themself!Jaymag is making a name for themself!
Send a message via MSN to Jaymag
Try the easy stuff first before pulling out the deck again. does the wine come from both speakers? if not, try switching the RCAs on the amp and see if it changes, or even disconnect the RCAs and see if the wine is still there
Jaymag is offline   Reply With Quote
Old 04-07-2008, 04:55 PM   #4
hammy's Avatar
hammy is an unknown quantity at this point
The whine could also be caused from a poor ground on the head unit. If of course you have an aftermarket head unit.
hammy is offline   Reply With Quote
Old 04-07-2008, 05:04 PM   #5
grounding your amp straight to the battery isnt bad they say you should run a ground fuse reason being if your battery ground to chassis dies its gona search for ground elsewhere which at that point is the ground through your amp.... and looks like everyone hit the nail on the head with wine
amp ground to long or just not good enough
head unit ground
rca cables
Old 04-09-2008, 10:57 AM   #6
I cut about 12" of the ground and that did it. Thanks!
Old 04-09-2008, 05:40 PM   #7
Hemi-sphere Dancer
riperoo's Avatar
riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!riperoo is a Magnum Genious!
I prefer a Chianti......
riperoo's Sig:
Riperoo, Bucks County PA.
WWVMD?
2006 Magnum R/T AWD,
"The Blue Mule"
Haulin' ass and suckin' gas!
riperoo is offline   Reply With Quote
