Old 04-09-2008, 02:09 PM   #1
matthew barry's Avatar
matthew barry is a Magnum Expert in Training!matthew barry is a Magnum Expert in Training!matthew barry is a Magnum Expert in Training!matthew barry is a Magnum Expert in Training!
Dvd Overhead Install Help.......
I want to install a flip down unit in my 05 r/t but I think I will run into a problem with the sun roof. Has anyone installed a flip down unit with a sun roof and was it a hard process?
matthew barry's Sig:yeeeeeee haaaaaaaaaaw
matthew barry is offline   Reply With Quote
Old 04-09-2008, 02:11 PM   #2
Forcedfed's Avatar
Forcedfed is a Magnum Expert in Training!Forcedfed is a Magnum Expert in Training!Forcedfed is a Magnum Expert in Training!Forcedfed is a Magnum Expert in Training!
Send a message via Skype™ to Forcedfed
I'm glad you asked that! I was wondering the same thing.
Forcedfed is offline   Reply With Quote
Old 04-09-2008, 04:53 PM   #3
i guess not
Old 04-09-2008, 06:47 PM   #4
lilcardwell's Avatar
lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!lilcardwell is a Magnum All Star!
I was hoping to do the same thing, but I too have a sunroof. Looks like it may not work because I believe you need some support brackets to hold the unit to the roof.
lilcardwell's Sig:
06 RT Steele Grey Metallic
* AirRaid CAI * Superchips * VDI door kit * 22" Verde Chaos * E&G Classic mesh grill *
* Bassani exhaust * color matched splash guards & wiper cowl * side molding delete *
* rear wiper delete w/ BT wing * BT front emblem * AND MORE TO COME *
lilcardwell is offline   Reply With Quote
Old 04-09-2008, 06:54 PM   #5
MDF works wonders and will fit. I just found out that there are 2 tracks that the window slides on and that a piece of MDF can be glued in place then you screw your dvd/tv to that. Sweeeeeeeeeeeeeeeeet.
Old 04-09-2008, 09:30 PM   #6
TheFOSS's Avatar
TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!
Sounds like a plan@! it should work if you make some measurements and take your time@! I also have the sunroof in an 05 R/T, but i think i may go with the headrest deal... just so i don't block the rearview...
TheFOSS is offline   Reply With Quote
Old 04-10-2008, 04:54 AM   #7
BWAAAAAAHHHHH!
MadDad's Avatar
MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!
I don't have a sunroof so I didn't post --- I have 10" Alpine flip down DVD player that I put in. It doesn't block my rear view too badly. I used some stock aluminum bars run between the bracing to mount mine. Here's some pictures
Headliner Removed
Mounting rails
Test mount
Finished
MadDad is online now   Reply With Quote
Old 04-10-2008, 05:57 AM   #8
24's and AWD? Absolutely!
DA HNIC's Avatar
I have a sunroof AND the 10.2" flip-down monitor with the built in DVD player BUT I didn't install it myself, BestBuy did.
With the sunroof in a Mag you have the sliding sun shade that slides into the hadliner. Well that part of the headliner that comes down enough to allow the shade to slide in is low enough and strong enough to allow you to connect the over head unit right there! You can also run the wires with no problems as well.
This is an old pic before I added a double-din NAV unit to the dash but when I did that, there were even MORE wires that had to run to the overhead unit.
All those wires basically run straight across the inside of the headliner to the B-pillar on the PASSENGER side, along the upper part of the door sill and down the A-pillar. Or, the wires can go down the B-pillar to the bottom of the door sill and along the scuff plate under the carpeting.
DA HNIC's Sig:
Old 04-10-2008, 09:22 AM   #9
Thanks for the info guys, i plan on the install for next week. one in my mag and one in the womens truck. pics to follow.
Old 04-10-2008, 10:01 AM   #10
The Stone White Specter
Pure Eight Clothing's Avatar
Pure Eight Clothing is making a name for themself!
Send a message via AIM to Pure Eight Clothing
Good luck... i would love to get a dvd player!
Pure Eight Clothing's Sig:
Lookin' Good.
MODS
  • 22'' Status Wheels
  • Eibach Pro-Kit Springs
  • 5% Limo Tint All Around
  • K&N Cold Air Intake
  • Ash Burl Wood Dash Kit
  • Altezza LED Tail Lights w/ NiteShade Tinting
  • Debadged w/ Custom Skull Hood Badge
  • Interior Blue LEDs
Pure Eight Clothing is offline   Reply With Quote
