Old 08-01-2008, 08:18 AM   #131
Bigg Boy's Avatar
Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!
Send a message via AIM to Bigg Boy
Originally Posted by Bay Area Magnum View Post
I will say this you are a talented MOFO....God damn I wish I had 1/2 of your talent..Now the dad side comes out..I use to have a banging system in my wrangler.(nothing compared to yours).I didnt notice any hearing problems till about 5 years ago..It sneaks up on you. Also moving to Orlando ..Are you towing a trailer lol cause you got no room now...Also be careful in Orlando..That sh*t will be gone in a minute...
Keep us posted man....I may have some work down here for you..
Id like to put a component set in each door and a single 10 in the back..
Thanks alot man, I'm not pulling a trailer, gonna pack the car out best I can... then ship the rest down... I will be more then willing to help you out when I'm down there, I will still have my job with the company I'm with so I can still get just about anything we would need for your install... I just dont what tools I would have down there with me.... you want a custom box? if so I'll build it before I come down..... I'll PM you my number.... give me a call.....
Originally Posted by kingswingin View Post
I've told you before - and I'll tell you again... you do some sick work man! Those are MONSTER subs and I bet it's nearly unbearable when you have them cranked! You running any capacitors?? I wouldn't think you'd have voltage issues with a 2nd battery - but those amps are ridiculous, so anything goes I guess, eh?! Nice install man, can't wait to see the doors!
No caps, caps dont do anything, they mask problems.... Voltage problem was fixed.... had a high independence ground...
Bigg Boy's Sig:160DB+ Here I Come
Bigg Boy Customs
www.havocaudio.com
2007 Dodge Magnum SXT (In the works)
*Eclipse Avn7000
*8 6.5" 02 audio mids,8 sound stream tweeters fiber glassed in the front doors (alot more to come)
*Subs?
*Amps? Too Much Power
*3 Kinetik HC2400
*2 runs 1/0 wire all around
*3 Bulk Packs of Dynamat
*Air bagged rear
*250a alt, maybe duals
Bigg Boy is offline   Reply With Quote
Old 08-01-2008, 08:21 AM   #132
LX Aficionado
kingswingin's Avatar
kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!kingswingin is a Magnum Genious!
OOOOh - something I can learn. Do explain if you would... thanks!
kingswingin's Sig:
KSD
Check out my Cardomain...
2005 Magnum RT-4128 180º t-stat, K&N 63 intake, NC-SXT grille, Mopar 'M' vinyl badges, skull & BT shifters, skull valve caps, crossbones tail cover, custom-painted engine bay w/skull graphics, auto-light mod, VHT tinted tails, eyelids, Flowmaster 40's, no resonators, SuperChips Flashpaq, Audiobahn subs, Alpine V12 amp
Future Mods
painted calipers, black chrome pedals, black powdercoat RT wheels, more paint
kingswingin is offline   Reply With Quote
Old 08-01-2008, 08:27 AM   #133
Bigg Boy's Avatar
its a bad ground meaning there is so much resistance between the connector and where its connecting too
I sit at 13.2v at full tilt with all ~5,000w rms going...
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
Old 08-01-2008, 08:33 AM   #134
LX Aficionado
gotcha - just never heard it called 'high independence' before. Moved the ground and fixed your voltage?
kingswingin's Sig:
KSD
Future Mods
Old 08-01-2008, 08:50 AM   #135
Bigg Boy's Avatar
some what sanded more paint off... and tacked a metal washed around the bolt to its tack weld to my ground, then put the ring terminals back on....
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
Old 08-01-2008, 09:15 AM   #136
Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!
Got the back all done...... Man does this thing pound!
Looks good and I bet it POUNDS!
. . but I am not too fond of the amp location and battery location with those visable wires. . . But that's just me.
Also, I would suggest putting a black or vinyl wrapped trim piece around the port. I think it would look a lot cleaner than just having the cut vinyl as the edge. But again just my opinion.
You say you have 5,000W RMS!?!?! What kind of amps are those?
Chutsk10 is offline   Reply With Quote
Old 08-01-2008, 09:33 AM   #137
BakNdaHood... CM4Lyf!
JRob007's Avatar
JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!JRob007 is the one everyone should be listening to!
Man that looks good!!! Can't wait to see the doors finished up!! Great job again Bigg Boy!
JRob007's Sig:
JRob007 is offline   Reply With Quote
Old 08-01-2008, 12:18 PM   #138
Evaluating...
MagWag's Avatar
5k RMS!?!?! CHRIST!
MagWag's Sig:MEMBERS MAP!
www.myspace.com/thompstud
No, No, NO DRAMA!
Old 08-01-2008, 12:31 PM   #139
TheFOSS's Avatar
TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!TheFOSS is a Magnum All Star!
WOW BigBoy.. great setup.. i can't wait to see a video of a midget bouncing on the roof from the bass!@ lol
TheFOSS's Sig:
2005 InfernoRed R/T
Mods:
Engine: Mopar CAI , JBA Shorty Headers , Diablo Predator , Custom painted engine cover and pillers, BT oilcap, fuse box cover, power steeriing, and washer fluid cap
Exterior: Shaved Side Moldings and Badges , Tinted Tails
Interior: Red C/F Dash Kit , BT shiftknob , Modified Shifter
TheFOSS is offline   Reply With Quote
Old 08-01-2008, 08:05 PM   #140
Bigg Boy's Avatar
Yep about 5,000 rms.... amps do about 1,700w rms at 1 ohm.... high amp does about 1,100w rms (i believe)... so thats about 4,500w rms and if i do my rear doors i will be well over 5kw rms
Amps are Md2d's
Roof actually doesnt flex to much...... the back hatch flex like crazy....
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
