Old 07-17-2008, 11:21 PM   #1
Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!Chutsk10 is a Magnum All Star!
Base radio HU wiring?
So I just pulled out my radio to see what I am looking at for the weekend deck install hoping that it would be a simple switch of the plug from one HU to the next but unfortunatley they are different.
Just wondering if there is a plug and play harness to go from the stock system plug to a single DIN run of the mill aftermarket HU?
Also, does anyone know/ have the wiring schematic of the stock wires (ie. which color wire is for what) just incase I can't get my hands on a plug and play harness?
Thanks
Chutsk10 is offline   Reply With Quote
Old 07-18-2008, 12:21 AM   #2
3.57MagnuM's Avatar
3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!
The harness isn't expensive.
If you buy one it has the color codes on the package.
The only things you're gonna have to look for are a switch source and an illumination source (if the unit uses it and you want to use it).
You'll also need the antenna adaptor and the mounting kit.
Good luck.
3.57MagnuM's Sig:"I did absolutely nothing and it was everything I thought it could be"
"I'm just a dog chasing cars. I wouldn't know what to do with it when I caught one. I just do things"
Originally Posted by JonnyO
Live to Drive Don't Drive to Die
3.57MagnuM is offline   Reply With Quote
Old 07-18-2008, 12:29 AM   #3
I know thy aren't expensive but if I can't find on locally I would rather just cut and solder the existing wires to the harness I do have that fits into my HU. I don't want to have to wait a week to have one mailed in so if anyone knows the wiring layous that would be great.
I have the plastic install kit and will have to look into the antena thing I suppose.
Also, what do you mean by switch? and illumination source?
I installed my other radio a few yars ago and figgured that stuff out but it has slipped my memory.
Old 07-18-2008, 01:09 AM   #4
Ok so i thought I would read some posts now that I startd a new thread and I think I understand. . . kind of.
The stock stereo is wired so that it stays on once the car is off and will shut off when a door is opened. . . is this function controlled by the computer and not transferable to an aftermarket unit?
Sooo powerwise if I am not mistaken there are two constant 12v sources and no ACC. . .
So can I connect the two constant 12v sources to the 12v on my harness?
Then connect th ACC on the harness to the cigarette lighter and switch the fuse over in the rear to make this switching power?
Connect grounds to grounds obviously.
What about the two CAN bus lines. . . just tape them off and not use them for anything?
Old 07-18-2008, 12:08 PM   #5
Also, when switing the fuse in the rear what power to get switching power which power lines are affected? . . just the cig lighter in the dash?
Old 07-18-2008, 05:44 PM   #6
Humm no audio ethusiasts out there today?
3.57MagnuM I noticed you had similar questions and your thread doesn;t really result in definitive answers. . . I bet you have the install complete so maybe a better description of the power/ ACC install would be well appreciated. . .
Old 07-18-2008, 09:36 PM   #7
3.57MagnuM's Avatar
I used the cig lighter in the ash try for the switch source. I'm not sure if only the cig lighter in the ashtray is affected when doing the fuse move.
The radio staying on after ignition is off and going off after door opens is just part of the normal circuitry I assume since my aftermarket hu does the same thing.
The canbus lines just get taped off. There is no use for these with just a regular head unit that I have found so far.
The way I installed my unit is switch power ( usually red from the aftermarket hu ) to the cig lighter and the constant power ( yellow ) to the constant on the factory harness.
The illumination source on aftermarket hu's dim the display backlighting when your running lights are turned on. Same as the stock player at night. To use this feature I tapped into the illumination line that runs into the harness for the esp/hazard switches.
Other than that everything else should be a breeze.
As far as color codes are concerned I ran into some threads by jamminwagon that has the audio schematics posted.
Hope that helps you out.
Old 07-19-2008, 10:33 AM   #8
Hum, I don;t think my deck has an illumination wire. . . or so I never used that before. I thinkI understand the basics and i found the thread with the wiring schematic. Shouldn;t be too difficult.
Thanks for the help and my apologies for the repetitious thread. . .
Old 07-25-2008, 10:12 AM   #9
JamminWagon's Avatar
JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!
Take a look through my photobubket account I have many wirings
JamminWagon/manual snapshots - Photobucket - Video and Image Hosting
JamminWagon's Sig:
