Go Back   Custom Dodge Magnum Forums > Tech Articles > Engine/Performance Mods
Engine/Performance Mods Tech Articles only!
Old 08-13-2007, 05:53 AM   #1
05 MAG RT's Avatar
05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!
Fan assembly replacement (whole unit for cheap)
One of my fan motors died on me recently, I got this whole, brand new, lifetime warranty unit from this place who also has it listed on E-bay.
Price is great, I replaced the whole unit myself, very easy, just need to remove the air intake, the upper radiator hose, the main fan wire going to the shroud, then the 2 bolts holding the shroud, lift it up and remove, swap the wiring to the new unit, slide it back in, put the 2 bolts back, reconnect the main wire, put hose and intake back, add coolant to the top of the reservoir (will probably need more later).
Easy to do, takes 30 minutes or less for the average joe with basic tools, so easy, don't even need pictures to figure it out.
05 - 06 DODGE MAGNUM Radiator & AC Condenser Cooling Fan Assembly (seller name on E-bay is: igboys) (P.S.: unit costs more on E-bay than their store, they may need to update their price)
05 MAG RT's Sig:CHECK OUT MY RIDE (CLICK HERE)
See you there: www.lasvegascarshows.com
MY 42" LCD HDTV/360/5.1SETUP
The new 360 avatars suck big time, thanks MS!
Old 08-13-2007, 08:51 AM   #2
jayalbertcars's Avatar
hello that is good looking out thank you
Old 08-16-2007, 12:47 AM   #3
05 MAG RT's Avatar
I checked with the dealer before going on E-bay, he wanted about $135 for one motor, and the whole thing, about $400, yeah right!
Old 08-16-2007, 04:27 PM   #4
05 MAG RT's Avatar
BTW: symptom of only one fan working is your car will run around 248 constantly.
That's what happened to me, I thought I had a stuck thermostat, but after checking further I saw only one fan was working.
Old 06-29-2008, 01:52 PM   #5
Hemi? Noooooooo!
gangster wagon's Avatar
gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!gangster wagon is a Magnum Superstar!
Besides the temp how Else can you tell if they are working. never hear them come on. shouldn't they come on when the mag is parked but still running?
gangster wagon is online now   Reply With Quote
Old 06-29-2008, 01:56 PM   #6
Evaluating...
MagWag's Avatar
hook a battery up to the fan motor, if it omes on the motors good, if its not working still, its the relay
MagWag's Sig:MEMBERS MAP!
www.myspace.com/thompstud
No, No, NO DRAMA!
Old 06-29-2008, 02:10 PM   #7
Hemi? Noooooooo!
^^^ Thanks again ^^^
HTML code is On
