Go Back   Custom Dodge Magnum Forums > Tech Articles > Engine/Performance Mods
Engine/Performance Mods Tech Articles only!
Old 01-29-2008, 09:50 PM   #11
PennsyMagnumGuy's Avatar
PennsyMagnumGuy is just warmin' up!
75 bucks for a dipstick!?!?!?!
A little bit pricey, don't you all think?
PennsyMagnumGuy's Sig:
'06 Magnum SXT 3.5L
Blastin' Bobs 10dB
More to come...
PennsyMagnumGuy is offline   Reply With Quote
Old 01-30-2008, 05:40 PM   #12
bubbamagnum's Avatar
bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!
I do not want to kill everyone's hopes about the tranny dipstick idea, the reason why our Maggies do not come with a dipstick is because to be properly read the dealer has a device they measure tranny temperatures not necessarly the amount or volume of tranny fluid that is in the Maggie. I was talking to the dealer today about the TSB problem and they explained this to me. The dealer said they do not know of any dipstick that would work (like from a Ram or other Dodge vehicle) for our Maggies.
bubbamagnum's Sig:
Bubbamagnum Build ETA completion date August 1st,2008.
bubbamagnum is offline   Reply With Quote
Old 01-30-2008, 07:11 PM   #13
Headache is just warmin' up!
I am curious as to why they designed it without the dipstick, seems completely stupid to me at least. Does anyone know the cost of changing the tranny fluid at the dealer anyway..
05 mag, how much are the new o-rings for the benz, and do you know the part number. I work for Carmax and could prolly get them easier than trying to go to mercedes?
Headache is offline   Reply With Quote
Old 01-30-2008, 07:33 PM   #14
Check this thread out, it gives you the part number for the v6 and the v8.
2005 Dodge Magnum TSB's - Page 4 - LX Forums Modern Mopar Muscle
Also on the other forums there is a ton of threads that discuss this tranny leak problem. Just search for tranny leak and you should find just about anything you need to know. I do not know what the dealer would charge you for changing the fluid out.
bubbamagnum's Sig:
Old 01-31-2008, 12:28 AM   #15
05 MAG RT's Avatar
05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!
They're full of it, they obvioulsly want you to come in to get paid for the service, the miller dipstick in the link is what THEY use, the starscan is only to check the temp, so when it's hot (running temp) 60mm is fine.
60mm when hot has been proven to be fine, because when I was at the LXF, I had the same thread and someone went to the dealer to have them check the fluid level with the starscan and all that fancy, unecessary B.S., when he got home he checked the fluid with the dipstick that he bought himself (link) and it was 60mm.
Old 01-31-2008, 12:31 AM   #16
05 MAG RT's Avatar
Don't remember, but I know they were twice as much as the DCX rings, but they last forever, at least I hope they will, because when I had the tranny leak, I changed the o-rings with DCX rings and 2 months later it leaked again, so I got the MB rings and they've been on the RT for over a year and a half and there is not one hint of a leak, and I checked it good last month when I changed the oil.
Old 01-31-2008, 12:35 AM   #17
05 MAG RT's Avatar
I went there, out of waranty, they wanted 1 hour labor minimun they charge for anything they do, so they wanted $100, that's why I got the dipstick myself, it ended up being cheaper and I also changed the o-rings myself and checked the fluid myself afterwards.
I still check my trans fluid once in a while when car is at running temp.
Old 01-31-2008, 12:36 AM   #18
05 MAG RT's Avatar
The dealer said they do not know of any dipstick that would work .
Of course they said that, my parts dealer at Chapman dodge told me I could get the miller dipstick and check it myself, that's why I go there all the time, they don't B.S. me.
Old 01-31-2008, 12:40 AM   #19
05 MAG RT's Avatar
Sure it is not cheap, but you get the only dipstick that is for that transmission, with the mm markings..., and if you plan on keeping your Magnum for a long, long time like me, it's worth it, especially if you plan on changing your o-rings and service your trans yourself (I changed the filter and fluid when I first got my Mag used).
Old 01-31-2008, 12:40 AM   #20
Sounds like you have all of the answers...good for you
bubbamagnum's Sig:
HTML code is On
