| Engine/Performance Mods Tech Articles only! |
#21 |
Any questions? (I tried to answer everybodys' concerns)
Don't forget the green bean(s) ![]() |
#23 |
Found it Cheaper here
Found it Cheaper Not much cheaper though only $1.24 less but it is less
I cant believe a Dipstick costs over $70 ![]() SPX Miller Special Tools | Detail: 9336 - DIPSTICK if the link doesnt take you right to the part search for part # 9336 |
#25 |
Just so folks are aware;
There is no need to purchase a transmission dipstick, instead utilize a length of stiff wire. All one is doing is pushing in the tool, or a length of wire, until it bottoms out in the pan, pulling it out and measuring the fluid depth. If on wanted you could put markings on the bottom of the length of wire every 10mm, but a tape measure/ruler will do the same thing... Last edited by Hemissary; 08-12-2008 at 04:03 PM.. |
#26 | |
You could do like you said, but why bother, isn't better to get the real deal. Plus that plastic thing seems to be some kind of guide so that it stays straight when it's all the way down, if you use a flexible wire, it might bend or flex and give you a false reading: ![]() |
#29 |
Measuring the proper way "with" a temperature reading:
NAG 1 Dipstick and Temperature Measuring - DIY |
#30 |
Measuring the proper "way" with the DCX approved dipstiuck:
Transmission dipstick. |
