| Engine/Performance Mods Tech Articles only! |
Transmission dipstick.
Buy it here: Dipstick 9336 - 9336
30mm cold and around 60mm hot is fine. Temp chart in post #2 (page 5) Last edited by 05 MAG RT; 09-03-2007 at 05:49 AM.. |
Asian Persuasion
You can get them for less here and they are much prettier.
Billet Technology: Dip Stick Dodge & Chrylser LX Platforum Hey 05 MAG, hope you don't mind but I added the link for the Temp Chart. http://modsfaceoff.com/2005_dodge_magnum_TSB/21-011-05.pdf#search='transmission%20dipstick%209336' |
Asian Persuasion
Asian Persuasion
Weird my chart link didn't work, it worked on other forums, but not here, anyway you all have the info neccessary to check your own level, which is good because I had that trans leak at the plug twice, replaced the O-rings myself and I couldn't check the level, now I can.
I replaced the O-ring with the Mercedes Benz rings, they are more durable. Easy job to do, take 15 minutes. BTW: the BT covers and caps are just the covers, not the dipstick, even for the oil, you replace the top part and keep the original dipstick. I ordered almost all the covers and caps from BT 2 days ago (in red), I'll post pics when I have everything. Last edited by 05 MAG RT; 09-03-2007 at 05:33 AM.. |
#8 | |
Asian Persuasion
Those caps and covers should look really nice. Can't wait to see em'. |
#9 | |
FYI: I changed the trans fluid myself once along with the filter with it hit 50K, kind of a PITA to do because you need a jack (very high, had to use wood planks to raise the jack) to hold the engine/trans in order to remove the transmission crossmember to remove the pan and change the filter, I changed my O-rings while it drained.
You may want to have the dealer do it unless you like hard work and have time and have a dipstick (see link) BTW: changing the O-rings is very easy, any week end mechanic can figure it out, get the Mercedes O-rings (my new dodge dealer O-rings leaked again after 2 months), get the car up on ramps only on the passenger side (to avoid having too much fluid draining out), with a pair a large pliers, turn the plastic plug to remove the electrical plug, then with a I think 7mm socket, unscrew the bolt that hold the plug, pull the plug out, change out the O-rings on the plug after cleaning the plug well (fluid will drain, so get a bucket), put everything back, put the fluid back in and you're done, took me 10-15 minutes the second time I did it. Also, about the water getting in the transmission thru the dipstick tube is an easy fix, just need to apply a lot of silicone at the base of the dipstick. Last edited by 05 MAG RT; 12-27-2007 at 06:12 AM.. |
