Old 02-25-2007, 06:56 AM   #1
illinirocks is an unknown quantity at this point
Installing a new grille
I am new to customizing my Dodge Magnum. I recently purchased a new grille, but I am not sure how to remove the stock grille. Any suggestions?
illinirocks is offline   Reply With Quote
Old 02-25-2007, 09:55 AM   #2
Grill Install
First, what type of grill did you purchase?
You will need to remove the front fascia from your Mag. The first time it will take some time, I can do it now in under 15 minutes. There are the six push pins on the top, all the little 7mm and 2-10mm bolts on the lower panel, 3-push pins in each wheel well, 1-10mm bolt on each side that holds the rear tip of the fascia. You will need to drill out the 3-plastic rivets in the wheel well on each side and put in new push in clips. Once everything is loose, just give the fascia a good smack forward with your hand below the headlights and it should come right off. Tip: lay a piece of carpet or towels on the ground to protect the paint.
If you have fog lights be careful when you remove the fascia and remove the bulbs.
The grill itself removes from the fascia easily after it is removed from the car.
Old 02-25-2007, 12:06 PM   #3
Thanks for the info
I purchased an E&G Grille. I noticed you pull the trim off the side of your Magnum. Is that a difficult process?
Old 02-26-2007, 08:37 AM   #4
The E&G is a good grill, so the install should be pretty straight forward.
It is best to remove on a warm day, it will just come off easier. Give it a gentle pull and clean up with Go-Gone and a good wax job....
Old 02-26-2007, 08:12 PM   #5
Side trim
Based on your response I assume the trim is just held on with adhesive?
Old 02-27-2007, 12:12 AM   #6
It has a strip on the top and bottom comes off easy...
Old 04-08-2007, 08:49 AM   #7
hop2000 is an unknown quantity at this point
What size push in clips did you get to replace the rivets and where did you get them? I'm going to install my grill next weekend and want to make sure I have all of the parts before starting it. Thanks.
hop2000 is offline   Reply With Quote
Old 04-08-2007, 10:08 AM   #8
MagneZeeOOM's Avatar
MagneZeeOOM is an unknown quantity at this point
Fair warning on removing trim panels!! It looks sweet, and some people get lucky, others very UNLUCKY. I was one of the latter. The tape came off no problem, but then the true story unfolded, BODYWORK, and paint blending, thus, and one of my trim pieces was taped off (LAZY BODY GUYS from some shitty shop) so now I have original color under where the trim used to be, and new color everywhere else, so a dark paint stripe that won't sand, buff, or wax out. Since it's used, and the carfax said nothing, it was an in-house job, to keep it off the books.
Now, for a simple mod to remove my trim to look a little cleaner, I'm either going to have to pay $500 to respray both passenger doors and blend them, or $2700 for a two tone all around, or $3700 for a complete color change. Unless I can scrounge up some new molding, or aftermarket type that will fit.
Just a word of caution, some people get lucky, some don't. Be very sure you want to remove it, and be careful doing so, in case you find something like that, put it right back on, and look the other way.
Just my two cents.
BUT WELCOME TO THE FORUM!!!
Post some pics and whatnot. See ya around.
MagneZeeOOM's Sig:MagneZeeOOM
'06 R/T Magnesium Pearl
Dub Air Intake; Magnaflow Cat back Exhaust; SC Flashpaq 91 Octane performance tune; 22"x9.5 Diablo Revolver Wheels; MDS Indicator wired into the ashtray; Shaved Badges, Trim, and Wiper; Tinted Tails (MoPower Chin Spoiler at paint)
MagneZeeOOM is offline   Reply With Quote
Old 04-08-2007, 10:26 AM   #9
dont replace the rivets my friend go to the local auto store and buy some clips and screws it will make everything ice and tight.......
Old 04-08-2007, 04:47 PM   #10
NC-SXT's Avatar
NC-SXT is a Magnum Expert in Training!NC-SXT is a Magnum Expert in Training!NC-SXT is a Magnum Expert in Training!
grille install
here ya go for an install from the top
http://www.dodgemagnumgrill.com/page6.html
NC-SXT's Sig:www.DodgeMagnumGrille.com
Custom grilles for your Magnum
Original NC-SXT Honeycomb Grill andTrue Srt style
NC-SXT is offline   Reply With Quote
