Old 11-21-2008, 10:06 PM   #1
Bigg Boy's Avatar
Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!Bigg Boy is a Magnum All Star!
Send a message via AIM to Bigg Boy
Removing Scratches...
I took the side molding off my car the other day and there much have been a rock behind the model and it scratched my car when I was taking it off... I've tried compounding it like 5 times, each time it getts better but its not gonna go away u guys have any other things for me to try, its just scratches in the clear...
Bigg Boy's Sig:160DB+ Here I Come
Bigg Boy Customs
www.havocaudio.com
2007 Dodge Magnum SXT (In the works)
*Eclipse Avn7000
*8 6.5" 02 audio mids,8 sound stream tweeters fiber glassed in the front doors (alot more to come)
*Subs?
*Amps? Too Much Power
*3 Kinetik HC2400
*2 runs 1/0 wire all around
*3 Bulk Packs of Dynamat
*Air bagged rear
*250a alt, maybe duals
Bigg Boy is offline   Reply With Quote
Old 11-21-2008, 10:48 PM   #2
Hemified's Avatar
Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!
Claybar maybe ?
Hemified's Sig:
Hemified
Mike
Colorado Springs, Colorado
2005 Dodge Magnum R/T:
5.7L Hemi Registry #974, RWD, Magnaflow Dual Exhaust, Air Hammer CAI,
Diablo Predator Sport Tuner, KMC Jacks & Five 20" Wheels,
20" Toyo Proxes, Lowered by
Eibach Pro-Kit, Black Halo Head Lights,
Black LED Tail lights, Painted Calipers, De-Molded/Badged,
Pappa John's Custom "R/T" Shifter Handle, Sony DVD/MP3 Player,
2 - 10.4" Head Rest Monitors, 2 - 12" JBL Sub's, 250 watt amplifier.
Hemified is offline   Reply With Quote
Old 11-22-2008, 12:05 AM   #3
---magnum minded---
GreenKing's Avatar
GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!GreenKing is a Magnum Genious!
Send a message via MSN to GreenKing
if your fingernail catches on them when you run across it, pretty much know that they wont simply buff out. General rule of thumb. Depending on how deep they are, you can sand (I prefer with a DA) the affected area with anywhere from 800-1500 (the deeper the scratch the courser the paper), wet sand with 3000 then buff the problem area and surrounding panels to give similar sheen. In my shop I use pretty much all ppg and 3M materials, and 3M's perfect-it line of compounds is amazing. Can be bought at any oriellys auto parts or similar. You will want the ultra-cut for deep scratches, normal cut for mild scratches, then the gold label swirl removal for a final shine. Make sure to use a wool pad on the first step compound, and the foam pad for the swirl remover. Low speeds are key, becuase the faster its moving the more heat it generates, and the easier it is to burn through the clear completely
GreenKing's Sig:
"Respect for religion must be reestablished. Public debt should be reduced. The arrogance of public officials must be curtailed. Assistance to foreign lands must be stopped or we shall bankrupt ourselves. The people should be forced to work and not depend on government for subsistence." - Cicero, 60 B.C.
GreenKing is online now   Reply With Quote
Old 11-22-2008, 01:15 AM   #4
DaddyGoFast's Avatar
DaddyGoFast is gettin' serious now!DaddyGoFast is gettin' serious now!
Be careful with sanding. I have noticed the clear on these cars are VERY thin. 1 MAYBE 2 coats. Do not get too aggressive or you could burn right through the clear entirely.
DaddyGoFast's Sig:Silver SRT8 Magnum - Ralph Gilles signature Edition
SRT Options I, II, III, Sunroof, Side Airbags, Auto Headlight Mod, Leather Console Mod, Daytona Shifter Mod, Stealth Auto SRT8 Pedals, Hood light, Hotchkis Sways, DC Strut Brace, Corsa Cat Back, Mopar CAI, Glove box light, Carbon Fiber steering wheel, Stealth Paddle Shifters.
Mods on the list to be done:
All done for now....
No Sig pic cuz it is too large!!!
DaddyGoFast is offline   Reply With Quote
Old 11-22-2008, 07:03 AM   #5
Quickly coming together....
Giantchief's Avatar
Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!Giantchief is the one everyone should be listening to!
Yep I used a mil measuring tool and it is below standard coatings for oem. Cheap ass dodge
Giantchief's Sig:
Giantchief is offline   Reply With Quote
Old 11-22-2008, 01:28 PM   #6
Bigg Boy's Avatar
I used some scratch doctor and did some very light wet sanding with 2200 and then 3000, and polished it out... I was scared to do it, but it came out great.... its allmost 100% perfect, there is one little line u can see and its only if u like straight down the car.
Bigg Boy Customs
www.havocaudio.com
*Eclipse Avn7000
*Subs?
*3 Kinetik HC2400
*Air bagged rear
Old 11-22-2008, 08:59 PM   #7
1blkperl's Avatar
1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!1blkperl is a Magnum Genious!
LOL, like I did ?
1blkperl's Sig:BAD BOY'S BAD BOY's..... WHAT-CHA GUNNA..DO WHEN THEY FLY BUY YOU
BEWARE OF THE PEARL !!
1blkperl is offline   Reply With Quote
Old 11-22-2008, 09:13 PM   #8
---magnum minded---
GreenKing's Avatar
cool, glad it worked for you!!
GreenKing's Sig:
