Old 04-14-2007, 02:15 PM   #1
cubsfan74's Avatar
cubsfan74 is just warmin' up!
Thumbs down Headlight removal
I am buying some HALO LED headlights and cant find how to remove the old ones. Anyone have some insight?
cubsfan74 is offline   Reply With Quote
Old 04-14-2007, 03:06 PM   #2
here is a video
HowNotTo2.html
Old 04-16-2007, 03:46 PM   #3
cubsfan74's Avatar
Thanks alot
Old 04-16-2007, 03:47 PM   #4
No problem......
Old 04-24-2007, 10:01 PM   #5
geezie20's Avatar
geezie20 is an unknown quantity at this point
Thanks great video
geezie20 is offline   Reply With Quote
Old 04-26-2007, 06:08 PM   #6
Magnum Marshall is an unknown quantity at this point
I tried to open your video and I couldn't. I bought a set of Halo lights with LEDS along the top and need to figure out how to wire it also. Any ideas??
Magnum Marshall is offline   Reply With Quote
Old 05-01-2007, 02:51 PM   #7
Obsidian's Avatar
Obsidian is an unknown quantity at this point
Solder all the black wire to one lead, then connect that to the black wire on your blinker light harness and do the same with the white wires and connect them to the brown wire on your blinker light harness.
The long stem little light goes to the small hole behind the long light on top, the blinker light goes to the inside hole, looking at the light from the front and then connect the remaining connections.
Hope this helps!
Obsidian's Sig:
Obsidian is offline   Reply With Quote
