Disable keyless headlight!!
CustomMagnums.com is the premier Dodge Magnum forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Results 1 to 11 of 11
    Junior Member kadaf is an unknown quantity at this point
    Sep 2009
    2
    Hello everyone, Im puzzled on how to disable the keyless remote headlight function(when you unlock the car headlights come on) on a 2008 Magnum. I read the manual and it only gives info on disabling on a Magnum equipped with EVIC. Does anyone have info on how to disable this feature?? I have HIDs and this function is going to shorting the life on the bulbs. THANKS!
    252.646.2160 Grille Master NC-SXT's Avatar NC-SXT is a Magnum Superstar! NC-SXT is a Magnum Superstar! NC-SXT is a Magnum Superstar! NC-SXT is a Magnum Superstar! NC-SXT is a Magnum Superstar! NC-SXT is a Magnum Superstar! NC-SXT is a Magnum Superstar! NC-SXT is a Magnum Superstar!
    Jan 2006
    2,412
    You should be able to program it from your key, double check the manual
    "INSTITUTIONALIZED" JERKDOGG's Avatar
    JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious! JERKDOGG is a Magnum Genious!
    May 2008
    5,691
    Here we go-try this.....
    this is a list of a few things you can do with the FOB you dont need EVIC:
    To turn off/on "Flash Lights On Lock/Unlock":
    1. Press the UNLOCK button for 4 to 10 seconds.
    2. While the UNLOCK button is pressed, (after 4 seconds) press the LOCK button. Release both buttons.
    The "Flash Lights On Lock/Unlock" feature can be reactivated by repeating this procedure.
    To turn off/on "Remote Unlock Driver's Door 1st":
    1. Press the LOCK button for 4 to 10 seconds.
    2. While the LOCK button is pressed, (after 4 seconds) press the UNLOCK button. Release both buttons.
    The "Remote Unlock Driver's Door 1st" can be reactivated by repeating this procedure.
    To turn off/on "Sound Horn On Lock":
    2. While the LOCK button is pressed, (after 4 seconds) press the PANIC button. Release both buttons.
    The "Sound Horn On Lock" feature can be reactivated by repeating this procedure.
    I tried this last procedure using the UNLOCK button and PANIC button together. It didn't seem to do anything. If anyone else finds that it changes something please let the Forum know.
    Automatic Door Locks at 15mph:
    For vehicles not equipped with the EVIC, the Automatic Door Locks can be enabled or disabled by performing the following procedure:
    1. Close all doors and place the key in the ignition.
    2. Cycle the ignition switch between LOCK and ON and back to LOCK 4 times ending in the LOCK position.
    3. Depress the power door lock switch to lock the doors.
    4. A single chime will indicate the completion of the programming.
    Automatic Unlock:
    3. Depress the power door unlock switch to lock the doors.
    May 2008
    5,691
    Juzt tried this and it workz only for the turn sigz to turn off or on when locking and unlocking!!!!!
    May 2008
    5,691
    only if you have evic, at least that is what my manual says
    Turn Headlights On with Remote Key Unlock
    This feature activates the headlights for up to 90 seconds
    when the doors are unlocked with the transmitter. The
    time for this feature is programmable on vehicles
    equipped with the Electronic Vehicle Information Center
    (EVIC). For details, refer to “Turn Headlights On with
    Remote Key Unlock,” under “Personal Settings (Customer
    Programmable Features),” under “Electronic Vehicle
    Information Center (EVIC)” in Section 4 of this
    manual.
  7. #6
    ^you cant see my mag... hahaha 'Couve Mag's Avatar
    'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar! 'Couve Mag is a Magnum Superstar!
    Aug 2008
    Vancouver, WA
    4,348
    very useful info jerkdogg... thanks for that...
    MAGNUM....... Not just a condom anymore....
    PDX MAGNUMS: http://www.custommagnums.com/forums/...iscussionid=43
    Originally Posted by Manny08
    "How do you fit the really big meats in the rear? "
    YOU SPIT ON IT FIRST..
  8. #7
    May 2008
    5,691
    Anytime BRO!!!!!
  9. #8
    Praise the Lowered! RobsSXT's Avatar
    RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious! RobsSXT is a Magnum Genious!
    Apr 2009
    Calgary, Alberta | Morgan, Utah
    2,688
    that was such a good post mr.jerkdogg I found it worthy of a greenie.
    2005 AWD SXT | 45K Miles | 20" Boss Rims | Hankook Tires | CAI | BCRacing Coilovers | DVD Headrests | Pyle 7" Double DIN DVD | Whelen Strobe Kit with AAC Wireless Remote | Billet Grill | Wiper Delete | Ported/Polished TB and AECarbon Lower Manifold | Diablo | Big Bully Catch Can | Color Matched Fuse Box-Wiper Nozzles-Eyebrows | Pioneer 12" in Slim Box
    www.mydodgemagnum.com
  10. #9
    May 2008
    5,691
    Thank U BRO!!!!!
  11. #10
    Member ozzo's Avatar ozzo is a Magnum Expert! ozzo is a Magnum Expert! ozzo is a Magnum Expert! ozzo is a Magnum Expert!
    Jul 2008
    132
    kadaf - w/o evic, I don't think there's a way (that I know of). I've wanted to do this as well and I think it'll involve geting hooked up to a starscan to get the option altered.
  12. #11
    Sep 2009
    2
    THANKS guys for the reply's.
