Old 12-07-2005, 06:04 PM   #1
Administrator
admin has disabled reputation
Debadging Question
Has anyone reomved the side mouldings or the badges/emblems on their Magnums? Are they just some strong adhesive or are there holes behind them? Whats the best way to remove them? Take a piece of fishing line and heat up the emblem and carefully remove?
admin is offline   Reply With Quote
Old 12-07-2005, 07:31 PM   #2
JamminWagon's Avatar
JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!JamminWagon is a Magnum Expert!
Removed mine the day after I got the Magnum. No holes, everything is held on with 3M type tape. I just took a small straight bladed screw driver and pried the end up and then pulled. Took goo-gone and cleaned up the goo. Then a coat of wax.
JamminWagon's Sig:
Old 12-07-2005, 08:30 PM   #3
CreatedByOne is just warmin' up!
just get some dental floss, and saw it back and forward , it will cut right through the adhesive. All emblems and moldings are taped on, even the back one, no matter what it looks like. just roll the rest of the bulk of the adhesive with your thumb, then use some goo gone at the end to get off the rest. Remember to wash and wax when you are done.
CreatedByOne is offline   Reply With Quote
Old 12-07-2005, 09:37 PM   #4
grinner's Avatar
grinner is a Magnum Expert!grinner is a Magnum Expert!grinner is a Magnum Expert!grinner is a Magnum Expert!grinner is a Magnum Expert!
I just pulled em off. The pain under the side moldings was already showing bad signed of early dammage due to trapped moisture:
the ram head badges are the hardest to get off. I just peel then rub the gum off with my thumb. Ya don't wanna do more than one magnum per day this way. Water blisters blow.
I doubt any badges will cause dammage but I don't recomend anybody keeping these side moldings on their car. Door dings are cheaper to fix than rust and thats what thise fugly things promote.
grinner's Sig:
grinner is offline   Reply With Quote
Old 12-08-2005, 01:43 AM   #5
northeastern08's Avatar
northeastern08 is just warmin' up!
Send a message via AIM to northeastern08
i also used the flossing method to get my badges off...then used a little heat and a putty knife to slide em off...almost no goo left this way...what was left came of no prob
havent taken off the side molding yet...might do that if i paint the car
-todd-
northeastern08's Sig:Todd K
Long Island, NY
2005 Dodge Magnum R/T
northeastern08 is offline   Reply With Quote
Old 12-08-2005, 09:33 AM   #6
Gumby is just warmin' up!
Your brave trying with a putty knife, one little slip could have been bad news...
I did mine the same way grinner did and both of my thumbs were blistered.. there is a 3m wheel you can by from automotive supply shops that attaches to a drill and removes it with out damaging the paint or your thumb
Gumby is offline   Reply With Quote
Old 12-08-2005, 01:16 PM   #7
i know what you're thinking, but it wasnt that bad...i only took off the little Hemi Badges and it was a piece of cake, i was just sharing my technique...and the putty/spackle flat knife really didnt seem like it was going to do any damage as long as i was careful...the heat was the key in my removal, made everything so much easier...if you are scared of heating it up, wait for a real hot day and they should come off nice and easy
my 2 cents
Long Island, NY
Old 12-09-2005, 06:53 PM   #8
grinner's Avatar
I used a plastic putty knife to get under the ram logo on the back. That one is on good and it was too dang cold to get my nutscratchers up under there well enough to get a snag goin. I did end up scratchin it a little. Bugged me till it was shaved and painted. On the other magnums I have shaved, I just used my finger tips. No worries that way. I never have used the dental floss/fishin line trick. Wish I would have known about it when I did mine... or back when I had a window tint/autographics shop.
I did use 3m's wheel for adhesive some but my thumb was always better and safer. I'm gonna have to invent a 3rd thumb... just a stock of rounded urithane that would buff the stickm off without scratching. I may have just discribed a tiny dildo but I think it'd sell.
grinner's Sig:
Old 12-10-2005, 01:24 AM   #9
multi-purpose...heh
Long Island, NY
Old 12-10-2005, 10:41 AM   #10
Go Dupont Racing!
Dupie24's Avatar
Dupie24 is just warmin' up!
My thumb didn't get blistered to bad, I had my son do one side and I did the other. Lots of goo-gone once the moulding is off. I hear 3m makes a automotive adhesive remover that works better than goo gone. I had to machine polish the side where the moulding was to get rid of line in the paint, I was real concerned at first, but after buying a porter cable polisher, bamm! no more lines and Manfred looks better than ever
Dupie24's Sig:We have it now! Life is good!
Dupie24 is offline   Reply With Quote
