Old 09-25-2007, 01:53 PM   #1
BIGDADDYIRISH's Avatar
BIGDADDYIRISH is just warmin' up!
Powder Coat
I Have A Buddy That Just Bought A Powder Coating Machine..... Do You Guys/ladies Think That The Powder Coating Will Stick On The Brake Calipers?
BIGDADDYIRISH is offline   Reply With Quote
Old 09-25-2007, 02:12 PM   #2
it would but your asking for allot of work powder coating you need to coat with the powder then bake it on in an oven you will more then likely need to remove them from the car and disassemble....your better off using regular caliper paint.......
Old 09-25-2007, 02:21 PM   #3
well i know all that work is going to be required....but here in the next month or so i will be getting a air kit for it so things will need to be taken off. so i just figure ill kill 2 birds with 1 stone
Old 09-25-2007, 02:40 PM   #4
I would think it would work so long as its prepped right, but you should only coat the outside. Powder coating is thicker than paint and will change the tolerances around the pad clips, etc. and you definitely dont want it where the pad meets the caliper of anywhere near the pistons (which I dont think you can remove from the caliper)
Old 09-25-2007, 02:49 PM   #5
Well thank you for that tip Mr. Modderator =)
