Old 10-05-2007, 02:11 PM   #1
ControlledChaos's Avatar
ControlledChaos is gettin' serious now!ControlledChaos is gettin' serious now!
Fog Light bezels
Basically the topic says it all. Im in the process of painting different pieces on my front end. I already did my grill in a gloss black and also my front plate bracket as well so they match. Now im looking at it and the fog light bezels are a dull black. So I peeked at them but have not a clue on how to remove them. I figured someone here knows how.(Im looking in your direction color match guys!)
ControlledChaos is offline   Reply With Quote
Old 10-05-2007, 02:17 PM   #2
matthew barry's Avatar
matthew barry is a Magnum Expert in Training!matthew barry is a Magnum Expert in Training!matthew barry is a Magnum Expert in Training!matthew barry is a Magnum Expert in Training!
there are clips behind the light that need to be taken out. remove the lower plastic under the front facia look up and they are right there and they ae a pain in the a$$ to get out.
matthew barry's Sig:yeeeeeee haaaaaaaaaaw
matthew barry is offline   Reply With Quote
Old 10-05-2007, 02:17 PM   #3
there are clips behind the light that need to be taken out. remove the lower plastic under the front facia look up and they are right there and they are a pain in the a$$ to get out.
Old 10-05-2007, 02:38 PM   #4
BWAAAAAAHHHHH!
MadDad's Avatar
MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!
what he said! Take off the belly pans (4 10mm bolts in the rear a mess of 7 mm bolts on the front), pull the plastic slip rivets in the wheel wells to complete the removal. Slide under and look at the rear of the lights toward the center of the grille. Two slip clips in each fog, pop them out (screwdriver, panel popper, pliers, whatever you choose). After the clips are out slide back out and gently pry the bezels out-- you should see the two "tabs" that hold them in place. Good luck!
Old 10-05-2007, 04:09 PM   #5
Or you could break the tabs off like I did. I removed the clips but they still didn't want to come off and I ended up breaking off one on each side. New ones were around $30....
Old 10-05-2007, 04:19 PM   #6
Vinniej's Avatar
Vinniej is just warmin' up!
Send a message via AIM to Vinniej
When I added my fog lights, I broke the tabs (not intentionally) on the blanks (not my new bezels) when I removed them. so beeee careful.
Vinniej's Sig:Current Ride:
2005 300C
Previous Ride:
2005 Magnum SXT
Vinniej is offline   Reply With Quote
Old 10-05-2007, 04:56 PM   #7
gusgus0513's Avatar
gusgus0513 is an unknown quantity at this point
hahahha i wish this thread would have been started like 4 days ago when i went to change my fog light bulbs and broke the clips $15 for each side
gusgus0513 is offline   Reply With Quote
Old 10-06-2007, 06:45 PM   #8
Well it was inevitable that I would break something on my car with all the pulling and twisting and other stuff that I have been doing to my car as of late and it just so happened to be those damn clips! Well one of them at least. Lucky for me the other one is doing its job of holding the whole thing together until i can another set of bezels. I painted them up to match for the meantime until I can go buy another set as the ones I have now are really chipped and banged up from driving. I also noticed that my fogs are cracked from rocks and other stuff flying at them so i guess I will be replacing those as well! I also lost one of those can metal spring clips that hold it in place. I dont know where it went as i popped it out with a screw driver and it went flying and bouncing around and never landed on the ground. I spent about an hour with a flashlight looking but never found it.
Also broke a clip on my rear passenger side door panel when I was waiting for the bezels to dry. Top right clip snapped off. Man was I bummed out on this so hopefully the glue i used will hold it back on.
Old 10-06-2007, 07:11 PM   #9
BWAAAAAAHHHHH!
MadDad's Avatar
Super glue will hold the tabs on the fog bezels (I broke/twisted one of mine), but didn't work to well on the push pin in the door panel that I broke.
Old 10-06-2007, 10:23 PM   #10
Evaluating...
MagWag's Avatar
as much interior work as u do MadDad, u shoul have a warehouse of clips and push pins!
MagWag's Sig:MEMBERS MAP!
www.myspace.com/thompstud
No, No, NO DRAMA!
