Need some advice please...
I have already ordered my rear wing badge from Billet. Since it probably wont get here till its cold outside I figuered I'd go ahead and remove the rear wiper this weekend. My concern is the plug for the hole. I read alot about using rubber grommets or cutting metal and magnets. I'm not sure the best way to go. My main concern is keeping the rain and/or snow from seeping into the hole. If any of you wonderful Magnumaniacs can help point me in the right direction for a secure/tight fit for the hole I would much appreciate it!
one more thing!!! wish me luck... my ride is going naked today!! hope theres no bubbles Thanks bunches.... |
In the corner with the crayons
you can seal around the back side of what you use to fill the hole with. I did the plastic one and painted it but it kept chipping off. Then I did the steel one that worked good then I put the BT wing over it.
here is the Plastic version I had repainted 3 times ![]() here is the steel version A square piece for the back sealed with silicone ![]() here is the painted steel piece ![]() ![]() here with the wing over it ![]() |
#5 | |
Thanks for the replies gentlemen. I didnt think of sealing it from the back... makes so much since to do that. Well i guess i'm off tomorrow to the hardware store to find something to fit the hole.
Anyone know about what size the hole is? I know its not perfectly circle, got a flat part on the bottom. |
