Old 01-15-2008, 09:38 PM   #1
MY357's Avatar
MY357 is just warmin' up!
HIDs installed but have issues!
Well I received my kit today and install was pretty easy...I ran a relay to power each ballast and everything works fine with the car running as in I have no flickering but the relays are buzzing like crazy, it sounds like there is an angry bees nest under my hood, I am thinking I will need do the capacitor mod that everyone else has seemed to need...Will the capacitor help equal out the load and make the relay coil stop freaking out? I know I have the relays wired right...Here is my install
MY357 is offline   Reply With Quote
Old 01-16-2008, 12:19 AM   #2
Wagnum's Avatar
Wagnum is an unknown quantity at this point
good luck. I am having troubles with mine as well. I bet the cap will be all that you need.
Wagnum's Sig:To date: Angle Eye Projectors w/ HID - R/T Chrome Grill - OEM Fogs - TomTom Nav hardwired into sunglass holder - auto headlights - turn signal mod - map light mod - Intake "muffler" mod.
Wagnum is offline   Reply With Quote
Old 01-16-2008, 07:02 AM   #3
MY357's Avatar
Hopefully, like I said there is no flickering or anything just the relays buzz like crazy
Old 01-16-2008, 08:45 AM   #4
Wagnum's Avatar
I will give you a bump, because i know the frustration....
Old 01-16-2008, 08:57 AM   #5
The Boss
steve's Avatar
Are you sure it is the relays buzzing? I know my ballasts make a loud humming sound when they are turned on and it gets quite as the ballasts warm up.
steve's Sig:Steve
Old 01-16-2008, 09:09 AM   #6
24's and AWD? Absolutely!
DA HNIC's Avatar
I don't know about them buzzing too loud but my HID's buzz also. But it's only when I used the car key fob to remotely open the doors and the headlights come on. Once I start the car it goes away.
DA HNIC's Sig:
