What's happening in Iceland
Thought I would give you all a little update on what is going on here in the snow. First I would like to appologize for crappy pictures, most taken with my cell.
But this is what I have done: LED bulb for the license plate light (more like HID's light) ![]() Activated auto headlights by modifying the knob ![]() here is the knob off, just pull hard enough!!! ![]() And here it is back on, in the auto position Painted brake calibers before ![]() ![]() After ![]() ![]() ![]() ![]() |
HID's for the headlights (8000K)
![]() This is how I mounted the ballast on the right side ![]() ![]() And on the left side ![]() ![]() As you can see, I just pushed the ballast between the boxes, there is no room for it underneath or anywhere else for that matter. And since I wasn't able to twist the new bulbs into the sockets when installing, I decided to take the headlights off the car (good to know how to if I will get my AAC halo's someday). I just followed the instructions I found here, but there is a little difference for the 2007 model, the bolts for the headlights are 8 mm instead of 10 mm, or you can use torx screwdriver as I did, then there is no way you loose the bolt under the light. More to come... |
Hemi-sphere Dancer
OK, right side ballast, my handyman radar is kicking in, is that a gutter strap holding the ballast in? the diamond shaped piece on front of the ballast. If it is, Kudos to you, I keep a stash of them around and use them on all sorts of jobs.
#10 | ||
ps. just got my danko chin spoiler in the mail today ![]() |
