Old 01-23-2008, 04:38 PM   #1
Nate Dawg is an unknown quantity at this point
Halo projector light complete housing swap
Hello I am new to this site and some people have already been a world of help, but just like any toy to tinker you always need more help with more mods. I need to know if anyone knows how to install and wire the complete halo projector light assembly swap of the OEM's can anyone help? Also what kind of time will be involved?
Thanks
Nader
Nate Dawg is offline   Reply With Quote
Old 01-23-2008, 06:05 PM   #2
do you have any pictures my friend
Old 01-23-2008, 09:41 PM   #3
Exclamation headlight question reply
umm yeah found one on the net headlight photo.jpgheadlight photo.jpg if you cant see it email me at najlouny@triad.rr and I can resend to you. Thanks again for all your help
Unfortunately I couldn't find one with a back view to show the extra wires and stuff but could probably try to take a pic of the back tomorrow and upload it!
Old 01-24-2008, 12:09 AM   #4
05 MAG RT's Avatar
05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!
I connected the halo wires to the markers/position wires. There are 3 wires altogether, 1 for the blinker, the other for the markers and 1 is neg, just have to test to see which one is the marker wire, splice it and connect all the wires for the halo and LED's on that wire, and the neg to the neg and that's it, very easy. I didn't use the LED's so I just connected the halos to the makeres wires, one set on each side.
Old 01-24-2008, 12:51 AM   #5
hope that helps you out Nate im sure they have the wires coming out for the halos so you can wire an on/off switch inside the car which might be a good idea
Old 01-24-2008, 07:57 AM   #6
Question lights
Why do you recomend a seperate switch for the halos? do they typically burn out quickly? If I wanted the LED's conected where do you recomend that I connect them? Should I connect them to the marker lights also? Blinkers? Anyways I appreciate the input.
Old 01-24-2008, 10:58 AM   #7
its nice to be able to just turn them on at shows or during the day separate from your headlights I would also do the same with the led strip...you can do it anyway you want just depends on what your looking for.
Old 01-24-2008, 04:39 PM   #8
Hello big al 470 i appreciate all the input regarding making a seperate switch for the halos and perhaps the same for the LED's, but i still need to know if I need to remove the front Fascia in order to replace the headlight and if so how do i get it on and off? Any recomendations
Old 01-24-2008, 04:40 PM   #9
Putting the both on a seperate switch is an idea that I never thought of and i think I will use though thnx again!
Old 01-24-2008, 04:50 PM   #10
kermit's Avatar
hey nate dawg , you dont need to take off the front fascia, there is a screw where the headlight and the bumper meet , bend it down a little and you can see it , and the other one is on top !
