Old 02-01-2008, 11:18 PM   #1
krewkut125's Avatar
Post Fender Removal
Here is a diagram of where each bolt is that holds the fender on. The arrows indicate where I was able to get to the head to undo it.
1. Broke off the rivet (top only), pulled back the fender well a little and snuck a ratchet with extension in there
2. Took headlight off and can reach it with ratchet (might also be able to reach it from the #1 position if second rivet is broken). There is also a plastic clip infront of the bolt as well holding the fender to the facia.
3. Just took ratchet and undid
4. Had to use a wrench because the foam that holds your hood strut is in the way a little (not to bad)
5 & 6. You have to take all the clips and rivets off the fender well and small rocker panel piece (mine I hade to take the whole thing off because i had metal rivets, not plastic) Then you can reach up in between the fender and the fenderwell to get to the heads. You might also want to just pull out the foam piece that is in your door (you will know when you feel it)
7 & 8. Are under the smaller piece of the rocker panel. The small piece should come off seperatly from the larger one with a clip but mine was held together by a metal rivet underneath. So the whole thing came off.
When all are undone pull up slightly on your fender and then out.
Old 02-01-2008, 11:26 PM   #2
Evaluating...
MagWag's Avatar
pics of it all put back together>?
MagWag's Sig:MEMBERS MAP!
www.myspace.com/thompstud
No, No, NO DRAMA!
Old 02-01-2008, 11:29 PM   #3
krewkut125's Avatar
lol, no not yet. I have talked to Jay and we think I have a alignment problem. I can not open the door more than about 3 inches so I stoped working at 10pm do to the fact I couldnt see. So I will be out there bright and early trying to fix it.
Old 02-01-2008, 11:31 PM   #4
Evaluating...
MagWag's Avatar
mine r on the way so im anxious!
No, No, NO DRAMA!
Old 02-01-2008, 11:58 PM   #5
bubbamagnum's Avatar
bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!bubbamagnum is a Magnum Genious!
For the first time doing one should take about 5 hours per door, it really helps to have two people when doing this.
bubbamagnum's Sig:
Bubbamagnum Build ETA completion date August 1st,2008.
bubbamagnum is offline   Reply With Quote
Old 02-02-2008, 02:05 AM   #6
Asian Persuasion
Magmania's Avatar
Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!
Nice info Krewkut.
I am adding this "How to" to my subscribed threads list.
Magmania's Sig:
Old 02-02-2008, 06:52 AM   #7
BWAAAAAAHHHHH!
MadDad's Avatar
MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!
Good job! Now when my kit gets here I'm all ready
Old 02-02-2008, 08:30 AM   #8
But You Can Call Me Chris
Cujofreak's Avatar
Cujofreak is a Magnum Superstar!Cujofreak is a Magnum Superstar!Cujofreak is a Magnum Superstar!Cujofreak is a Magnum Superstar!Cujofreak is a Magnum Superstar!Cujofreak is a Magnum Superstar!Cujofreak is a Magnum Superstar!Cujofreak is a Magnum Superstar!
So how difficult is the cutting that's required?
I've never cut anything, so i'm a beginner.
Cujofreak's Sig:
2009 Dodge Challenger SXT
Mods:
Engine: None
Exterior: Chrome Gas Cap, Tinted Windows
Interior: Pappa John Custom Shifter
Cujofreak is offline   Reply With Quote
Old 02-02-2008, 08:50 AM   #9
Chuckles_1205's Avatar
Chuckles_1205 is making a name for themself!Chuckles_1205 is making a name for themself!
Loooking good so far!!
Chuckles_1205 is offline   Reply With Quote
Old 02-02-2008, 08:59 AM   #10
Great info!
I'm guessing you're installing vertical doors? If you have the LSD kit the spacers go on the drivers side (top and bottom), and the weatherstrip (rubber and plastic thingy) on the leading edge of both doors needs to be removed or trimmed back. That should cure your alignment issues.... I hope
