Old 02-04-2008, 08:43 AM   #1
CHIEF's Avatar
CHIEF is a Magnum Expert in Training!CHIEF is a Magnum Expert in Training!CHIEF is a Magnum Expert in Training!
Chin Spoiler Questions
Hey all,
I've got a few questions on the Charger and Danko spoilers.
First, how does one modify the Charger spoiler to fit a Magnum properly, I have not been able to find any info, and it looks like you would have to cut it to get it to work.
Second, any body with the Danko in the Frozen North? I love the look, but I am afraid of adding a snow plow, since it is my daily driver. How about the shaved version, how much real clearance do you lose if you have OE suspension?
Thanks as always!!!
CHIEF's Sig:2005 Magnum RT RWD Inferno Red
AIRHAMMER CAI
Diablo Predator- Tweaked 91 CAI tune, Trans Mode 2
CORSA Catback
JBA (HHP) High Flow Cats and Mids
JBA Shorty Headers
Napa 191 - 180* Tstat
Nitto 420NT (255/55R18) Tires on American Racing Rogues
Flameball Shifter (http://www.flameball.com/)
Black Mesh Grille (http://dodgemagnumgrill.com/)
Alpine IVA-505 DVD Nav.
CHIEF is offline   Reply With Quote
Old 02-04-2008, 09:32 AM   #2
BWAAAAAAHHHHH!
MadDad's Avatar
MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!MadDad is the one everyone should be listening to!
Here's Bigal470's install on the Charger front lip Front lip
while I'm not quite in the Frozen North I do make some trips up to the mountains with my Danko Chin spoiler. I haven't had any problems with clearance (stock suspension AWD) -- it doesn't really project down as much as it does forward. I'm more cautious on large "dips" but I've only scraped once.
Old 02-04-2008, 09:35 AM   #3
CHIEF's Avatar
Thanks MadDad, do you have the standard Danko or a shaved one?
AIRHAMMER CAI
CORSA Catback
JBA Shorty Headers
Old 02-04-2008, 09:39 AM   #4
Strykker's Avatar
Strykker is a Magnum Expert!Strykker is a Magnum Expert!Strykker is a Magnum Expert!Strykker is a Magnum Expert!
Question 1: you have to cut a small V on the backside center of the charger unit so you can snug it up to the magnum fascia.
Questoin2: The Danko unit projects an optical illusion when you look at it from the front, it is actually not any lower than the rest of the bottom of the car. It does protrude forward about 2 inches, so when you look at it from the front there is the appearance of it looking like it is almost dragging the ground.
Strykker's Sig:
Sig by Hazman
Magnum Owners Club #1293
5.7L Hemi Registry #00619
http://www.cardomain.com/ride/2331622
Strykker is offline   Reply With Quote
Old 02-04-2008, 09:44 AM   #5
CHIEF's Avatar
On the Charger lip, I've got one, but it seems like the rivets wouldn't hold due to the stress. Do they hold up ok?
AIRHAMMER CAI
CORSA Catback
JBA Shorty Headers
Old 02-04-2008, 10:18 AM   #6
rollin and lookin good
chance6384's Avatar
chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!chance6384 is a Magnum Genious!
Send a message via AIM to chance6384 Send a message via Yahoo to chance6384
I have a charger lip like your asking about.... I used plastic wall anchors to hold mine on... I didnt used the rivets that came with it.
So far i havent had any trouble with it ... I do have to mod to sit flush ... but I am not doin that til spring. been thru car washes and a few snows... no problem so far... hope that helps
couple shots before I changed out my fogs.....
chance6384 is offline   Reply With Quote
Old 02-04-2008, 01:07 PM   #7
Drivin the Kasket Karrier
2001shadowace's Avatar
2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!2001shadowace is a Magnum All Star!
I have the Charger spoiler I used bolts and flat washers to install. I didnt modify it at all other than I put an extra bolt and some fender washers(bigger around) to help pull the center up tight!
2001shadowace's Sig:
2001shadowace is offline   Reply With Quote
Old 02-04-2008, 01:10 PM   #8
CHIEF's Avatar
Cool, I'll just start hoggin' out some areas with the dremmel and use some bolts to get it on there, thanks for the input!!
AIRHAMMER CAI
CORSA Catback
JBA Shorty Headers
Old 02-04-2008, 01:11 PM   #9
FloridaRT's Avatar
FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!
I just installed the unshaved Danko chin spoiler on my Magnum, I have the stock suspension. There is about 6.25 inches of clearance from the bottom of the spoiler to the ground (pavement).
The Danko spoiler is mounted using 9 bolts, 5 medium & 4 smaller ones.
Yes, you must drill 9 holes into your fascia to mount the spoiler.
You can do the install by yourself, but having an extra set of hands helps a lot. There is a thin rubber gasket that comes with the spoiler that gets put on, it helps sealer the spoiler and saves the paint from any rubbing.
That's my son doing the install on mine................
Bob
Old 02-04-2008, 03:29 PM   #10
Simply99's Avatar
Simply99 is just warmin' up!
I'm still waiting on mine. They sent me a shaved one instead of the unshaved one I ordered/bought. I had a appointment all set up to have it painted/installed with the thrid rear brake area and had to put it off.
Now they don't have a slot open for over a month due to the recent storm.
So I wasn't exactly thrilled so far.
Simply99 is offline   Reply With Quote
