Old 03-20-2008, 12:07 PM   #1
FloridaRT's Avatar
FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!FloridaRT is a Magnum All Star!
How Do I Remove Foglights To Install Halos?
Is there any easy way to remove the foglights, so I can install my Halos???
Thanks
Bob
Old 03-20-2008, 12:18 PM   #2
05 MAG RT's Avatar
05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!05 MAG RT is a Magnum Expert!
Foglights can be removed from the bottom after you remove the plastic shields, both of them, the big one for when doing the oil change and the small on under the radiator.
To install the Halos, which I almost went for, you'll need to cut the fog light lens at the base, put the halo ring and run the wires and re-glue the lens back on, it's tidious work but that's the only way.
Old 03-20-2008, 04:37 PM   #3
FloridaRT's Avatar
I know about installing the halos, just wondered if there was some "magic trick" to get the fog lights out.....
Thanks
Bob
Old 03-20-2008, 06:28 PM   #4
NOTPAID4MSRT8's Avatar
NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!NOTPAID4MSRT8 is a Magnum Genious!
Send a message via Yahoo to NOTPAID4MSRT8
FloridaRT, (BOB) the last time we conversed YOU SAID that your SON did all your work... LOL... Gotta get my SON involved with mine. You know us "ole timers" need "LOTSA" help, Jim
Seriously... good luck on your fog light halo mods... can't wait to see some pictures!
NOTPAID4MSRT8 is offline   Reply With Quote
Old 03-20-2008, 08:30 PM   #5
Once I had my headlights out I was able to reach down and remove the fogs.....
Old 03-21-2008, 12:39 PM   #6
Chapah's Avatar
Chapah is an unknown quantity at this point
Thanks
Bob
Hey FloridaRT,
I always follow this guide when changing bulbs or getting at my fog lights.
HID Low Beam and Fog Light Install
Hope it helps out and take pics so we can see your halos.
Perhaps even make your own guide for us!
Chapah's Sig:
Christian aka "CHAPAH"
2006 Magnum R/T AWD
www.LushWorld.com
Great boredom reliever!
Click pic to view larger image
Chapah is offline   Reply With Quote
Old 03-21-2008, 01:48 PM   #7
Capital1's Avatar
Capital1 is an unknown quantity at this point
Hope this helps, let me know if you need more info.
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Open hood and remove the upper radiator closeout panel (2 and 4).
  3. Remove the six upper fascia retaining fasteners (Refer to 13 - FRAME & BUMPERS/BUMPERS/FRONT FASCIA - REMOVAL).
  4. Remove the headlamp unit (Refer to 8 - ELECTRICAL/LAMPS/LIGHTING - EXTERIOR/HEADLAMP UNIT - REMOVAL).
  5. From behind the bumper fascia, disconnect the harness connector.
  6. Remove two fog lamp unit mounting fasteners.
  7. Remove fog lamp unit (1).
Capital1's Sig: FRIENDS Don't let FRIENDS Drive Stock
Capital1 is offline   Reply With Quote
Old 03-21-2008, 03:17 PM   #8
FloridaRT's Avatar
Yes, he will be doing this for me also, LOL.
Hard for the old man to do this kind of work, damn Arthritis.............
He will remove the units, I will install the Halos.
Bob
Old 03-22-2008, 12:08 AM   #9
05 MAG RT's Avatar
Thanks
Bob
I gave you the answer you wanted in the first line, easiest way is from the bottom.
Old 03-22-2008, 06:02 AM   #10
FloridaRT's Avatar
Yup, we will be doing it from the bottom..........................
Thanks
Bob
