Old 03-30-2008, 11:42 PM   #1
Monroe06's Avatar
Monroe06 is an unknown quantity at this point
Send a message via Yahoo to Monroe06
Need advice
I spent 2 days trying to put lights inside and under my magnum and wasn't able to figure out where to put them. There is nowhere under the front or back bumper to tie them up too. Has anyone had this issue and if so how did you do it.
Monroe06 is offline   Reply With Quote
Old 03-30-2008, 11:44 PM   #2
Xcbellx's Avatar
Xcbellx is a Magnum All Star!Xcbellx is a Magnum All Star!Xcbellx is a Magnum All Star!Xcbellx is a Magnum All Star!Xcbellx is a Magnum All Star!Xcbellx is a Magnum All Star!
what kind of lights?
Xcbellx's Sig:
BigBully Intakes ...Coming Soon
Xcbellx is offline   Reply With Quote
Old 03-31-2008, 08:53 AM   #3
krewkut125's Avatar
If you are talking about like neons or LED's I have the back zip tied to the little "lip" on the bottom of the rear bumper. I drilled 3 holes in the bottom lip with a dremel and then just fed zip ties through the holes and around the lights. For the front I took off the plastic shield thing and dremeled a notch out for the LED to shine through. I mounted the light on the inside of the pan with the little bracket things that come with the lights. Hope this helps, I can throw some pics up later today if you want (girlfriend took the camera).
Old 03-31-2008, 10:14 AM   #4
Monroe06's Avatar
Some pics would be awesome. We were able to do the sides but anywhere we looked to do the front and back there was just nothing.
My other question is did you drill into your floor board to get the wires inside? My friend kinda rigged it and there are wires showing on the outside. They work for now since there is a race/show this weekend, but I really want it fixed before the next one
Old 03-31-2008, 10:25 AM   #5
Eva - Ms. March 2009
Greg095's Avatar
Run all the wires up to the front of the car, and into the engine compartment. You can access the interior through the firewall on the drivers side. Pop the cover that is in the wiper cowl. You will see a black boot, This will give you access to the interior. You can also use the hole that the hood release cable goes through.
Greg095's Sig:
Old 03-31-2008, 10:31 AM   #6
krewkut125's Avatar
^^ That is exactly what I did with all my wires. The back tube wires I brought it over the rear axle where it wont hit anything then brought it along one of the side tubes and up through the engine bay to that pass through. Put the tube in the back with the wire comming out toward the drivers side then snake it up front along that side. I will take pics for you once my girlfriend gets out of school and bring the camera back.
Old 03-31-2008, 07:11 PM   #7
krewkut125's Avatar
Sorry it took so long to get the pics up but here they are:
Here is of the back
One more of the back
The front
Old 03-31-2008, 08:05 PM   #8
jayalbertcars's Avatar
hello i mounted my side tubes behind the body lip my front tube is mounted under the rad support i cut slots in the cover i also mounted my rear tube to the metal rear bar behind the cover i used the mounts that come with the kit but i also use tie wraps the key to under carriage lighting is to defend everything as best as is possible i also have 4 wheel well tubes and 2 - 4 foot tubes in the head liner all working together its 7 color 300 patterns it looks wild
Old 03-31-2008, 10:12 PM   #9
Monroe06's Avatar
thanks! this helps a lot. Hopefully the next few weeks I'll have it all done. and fixed better so the wires dont show.
Old 03-31-2008, 10:13 PM   #10
krewkut125's Avatar
No problem and if you have any more questions feel free to ask....
