Suicide Hinges......
i am currently testing a new suicide hinge idea.....it will have the ability to swing open 180 degrees...it will also be one hinge per side instead of the 2 i used to have on my original suicide modification.....it is a 2-stage hinge which is how it can manage to open the door 180 degrees.....when i first suicide modification done the hinges that i first had stuck through in the wheel well. Thus, makin it very hard to drive......but since then, i have been searching and studying different hinges. i am currently trying to perfect my theory of the 2 stage hinge system....it should be done by mid january.
i'll keep you posted Matt |
#2 | |
#3 | |
#4 | |
#5 | |
heres the temp hinge pic... |
here you go.......a sneak peek at suicide doors at the angle of about 145 degrees still adjusting the door and figuring out how much of the back part of the door needs to be modified but....slowly but surely.....
Matt |
#10 | |
