Old 05-06-2008, 10:45 AM   #1
hsh_ik0n is an unknown quantity at this point
stock sxt to stock sxt bumer swap
title should read "stock sxt to stock sxt bumper swap"
alright so heres the plan. i want to buy a stock sxt front bumper. no grill inserts or fog lights needed. after some modifications and a little bondo work i'll be swapping it out with my stock front bumper. so question is: is there anything im over looking? is there any wiring harness or brackets or tubing that runs through or attached to the front bumper? other then the bumper its self and the plastic rivits that run along the inner wheel well is there anything else that i need to swap out a stock sxt front bumper with the same exact oem replacement bumper??
Last edited by hsh_ik0n; 05-06-2008 at 11:41 AM.. Reason: well i really should start proof reading. sorry. was just in a hurry..
hsh_ik0n is offline   Reply With Quote
Old 05-06-2008, 10:50 AM   #2
eldiablo is an unknown quantity at this point
explain your self just a bit better dude
eldiablo is offline   Reply With Quote
Old 05-06-2008, 11:46 AM   #3
Ya lost me....if yur swapping out (replacing) the bumper like for like, then you should have everything you need.
Old 05-06-2008, 11:46 AM   #4
well basically im going to be doing something like the danko front grill. slightly different of course. along with the home made "danko grill" i'll be modding the lower grill and fog light openings. and probally relocate the license plate. problem is i dont want to do it to the stock bumper i have installed now. so i was asking how difficult would it be to buy a new stock oem sxt front bumper, and after doing all my mods to it. remove the old bumper for the new modded one. i just want to make sure im not overlooking something in the bumper swap.
Old 05-06-2008, 11:51 AM   #5
Yeah you'll be fine, its just held on by the removable plastic fasteners across the top, the fasteners in the wheel wells and the ones along the bottom. So long as you dont cut holes thru the bumper where the foam impact protector is (you can see it behind the bumper)
Old 05-06-2008, 12:08 PM   #6
dont need anything but the balls to do it.......
Old 05-06-2008, 12:10 PM   #7
Cappadocious is making a name for themself!Cappadocious is making a name for themself!
Big Shiney Ones !
Cappadocious's Sig:07 Black Magnum SRT-8
Cappadocious is offline   Reply With Quote
Old 05-06-2008, 12:22 PM   #8
I've got one at home I'm thinkin about cutting up as well...
You will not want to use regular Bondo on the fascia you will need to use flexible filler so it won't just pop out....it comes in a big syringe type dispenser.
Keep us posted...
Old 05-06-2008, 02:39 PM   #9
so i found one for a decent price but all they could give me was the oem part number.
4805768ab
is that for the sxt or se?? does it really matter. looks like the same front end to me..
Old 05-06-2008, 04:05 PM   #10
dopeskwyd's Avatar
dopeskwyd is just warmin' up!
as far as i know all the front ends are the same other than the SRT, wich is freakin awesome. you can see it on Bigal470's ride(equally awesome)
dopeskwyd is offline   Reply With Quote
