Old 05-21-2008, 09:14 AM   #1
kgb44's Avatar
kgb44 is just warmin' up!
LED Tail light install
Can anyone tell me how to install the LED Tail lights?
How do you remove the stock ones?
kgb44's Sig:2007 Black RT, AWD
Magna Flow Exhaust
JBA Shorty Headers & JBA Mids w/ High Flow Cats
AFE Stage II Cold Air Intake
20" Black Boss Wheels
Eibach Pro Kit
DeBadged
DeMolded
BT Skull& Crossbones Rear Emblem
Eyelids
8000K HID Low Beam & Fogs
Black LED Tail lights
Tinted Windows
kgb44 is offline   Reply With Quote
Old 05-22-2008, 10:59 PM   #2
fam0516's Avatar
fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!fam0516 is a Magnum Genious!
Send a message via AIM to fam0516
yes someone anser this question? r the stock tail light bulbs>
fam0516's Sig:
Keep callin it a hearse..N..Youll be in the back!
fam0516 is online now   Reply With Quote
Old 05-22-2008, 11:27 PM   #3
Fireman2118's Avatar
Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!Fireman2118 is a Magnum All Star!
Here's a link How to tint your taillights Click the link, look at the pictures and follow the instructions. It's easy.
Fireman2118's Sig:
Never mistake kindness for weakness!
Fireman2118 is offline   Reply With Quote
Old 05-22-2008, 11:28 PM   #4
Hemified's Avatar
Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!Hemified is a Magnum All Star!
I'll try explaining...
Open the back lid and on each side even with the tail lights you will see those "pop-out" fasteners (2 for each side). Just remove those first. Then there are 2 access doors that look like small speaker panels that just pop off. Right behind the grilles are heavy fabric flaps that open up. In that hole you will find a wing nut about 6 inches in (Note: the metal edges are sharp in here, be very careful). Simply remove the wing nut being EVER so CAREFUL NOT to drop them in the pocket of No Return !!! Then the whole lens assembly will slide back off the car. Installation in reverse... it's really that easy !!!
Good Luck & Have Fun
Hemified's Sig:
Hemified
Mike
Colorado Springs, Colorado
2005 Dodge Magnum R/T:
5.7L Hemi Registry #974, RWD, Magnaflow Dual Exhaust, Air Hammer CAI,
Diablo Predator Sport Tuner, KMC Jacks & Five 20" Wheels,
20" Toyo Proxes, Lowered by
Eibach Pro-Kit, Black Halo Head Lights,
Black LED Tail lights, Painted Calipers, De-Molded/Badged,
Pappa John's Custom "R/T" Shifter Handle, Sony DVD/MP3 Player,
2 - 10.4" Head Rest Monitors, 2 - 12" JBL Sub's, 250 watt amplifier.
Hemified is offline   Reply With Quote
Old 05-22-2008, 11:29 PM   #5
Hemified's Avatar
Hey Fireman.... using a link is cheating !!! J/K
Hemified's Sig:
Hemified
Mike
Old 05-22-2008, 11:30 PM   #6
This link makes it easier cause it explains it with pictures How to tint your taillights
Fireman2118's Sig:
Old 05-22-2008, 11:31 PM   #7
I was doing it your way and got lost....errr, ummm i mean tired...lol
Fireman2118's Sig:
Old 05-22-2008, 11:31 PM   #8
gutta3000's Avatar
gutta3000 is an unknown quantity at this point
1. Takeoff cover inside trunk
2. Unscrew bolt that holds tailight in place
3. Pop out plastic pins on side of the taillight
4. OEM Taillight pops out easily. might have to tug on it a little
5. With headlight out remove OEM bulbs from headlight, pop out reverse and turn signal bulb
6. Disconnect wire harness from the brake light bulb
7. I took off the weatherstrip from my OEM headlights so you can keep the water out. It fits perfectly with new headlight
8. Connect the wiring from the LED to the tailight wire harness. Make sure the 3 color wires match up
9. Pop reverse bulb and turn signal back in
10.Place taillight back on the car with weatherstrip and reverse the steps used to take the taillight off.
gutta3000 is offline   Reply With Quote
Old 05-22-2008, 11:32 PM   #9
Hemified's Avatar
Yupper, good call !!! Visuals are always nice !!!
Hemified's Sig:
Hemified
Mike
Old 05-22-2008, 11:33 PM   #10
I agree!
Fireman2118's Sig:
