Old 05-21-2008, 10:10 AM   #1
3.57MagnuM's Avatar
3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!3.57MagnuM is a Magnum All Star!
Removing front fascia.
Can anyone explain to me how to remove the front bumper?
Planning to remove the whole bumper when I install my danko grill and want to do the fog light bezels the same time.
Just need to know how to remove the whole thing.
Thanks.
3.57MagnuM's Sig:"I did absolutely nothing and it was everything I thought it could be"
"I'm just a dog chasing cars. I wouldn't know what to do with it when I caught one. I just do things"
Originally Posted by JonnyO
Live to Drive Don't Drive to Die
3.57MagnuM is offline   Reply With Quote
Old 05-21-2008, 10:21 AM   #2
Even Angels Cast Shadows
B00MER's Avatar
B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!B00MER is a Magnum Superstar!
http://dodgemagnumgrill.com/page6.html
B00MER's Sig:
^ Click for cardomain page.
| My Magnum Bookmarks
B00MER is offline   Reply With Quote
Old 05-21-2008, 10:25 AM   #3
3.57MagnuM's Avatar
I appreciate the attempt boomer.
But my plan is to remove the whole bumper, not just replace grill inserts.
I am putting in a danko grill and I plan to work on my fog light bezels at the same time.
It would be easier to do both if I can have the whole bumper off, not just be able to get to inserts.
Old 05-21-2008, 10:47 AM   #4
Atrus1212's Avatar
Atrus1212 is a Magnum All Star!Atrus1212 is a Magnum All Star!Atrus1212 is a Magnum All Star!Atrus1212 is a Magnum All Star!Atrus1212 is a Magnum All Star!Atrus1212 is a Magnum All Star!Atrus1212 is a Magnum All Star!
Send a message via AIM to Atrus1212
I have it in PDF format (it's for the 300 but my understanding is the mag is similar) just PM me your email and I'll send it to you.
Atrus1212 is offline   Reply With Quote
Old 05-21-2008, 10:48 AM   #5
B00MER's Avatar
Sorry I couldn't help that video just popped into my head when I saw your post, hope you find what your looking for.
B00MER's Sig:
| My Magnum Bookmarks
Old 05-21-2008, 11:13 AM   #6
Asian Persuasion
Magmania's Avatar
Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!Magmania is the keeper of all Magnum knowledge!
You remove the 6-8 fasteners at the top (like in that video).
I usually leave 2 of them loose but in place. These will hold the fascia in place until you are ready to pull the fascia off.
Remove the 8-10 screw fasteners at the under side where the belly pan meets the fascia.
Open up the front wheel wells by removing the 2-3 fasteners that attach it to the fascia. I believe these fasteners will have to be replaced once you remove them. I would get some speed nut clip and screw fasteners for that.
Once you have the well open there are 2 bolts (10mm I think), 1 on each side that hold the facia to the upper fender. These bolts are screwed into the fender vertically.
That's it. Pull out those last 2 fasteners at the top and grab the facia and pull it forward. If you have fog light assemblys, don't pull too far until you disconnect the harness connectors.
Magmania's Sig:
Old 05-21-2008, 11:32 AM   #7
Just make sure you have the replacement fasteners before you take off the fascia, so you don't have to worry about getting it back together...
Old 05-21-2008, 11:46 AM   #8
3.57MagnuM's Avatar
I usually leave 2 of them loose but in place. These will hold the facia in place until you are ready to pull the facia off.
Remove the 8-10 screw fasteners at the under side where the belly pan meets the facia.
Open up the front wheel wells by removing the 2-3 fasteners that attach it to the facia. I believe these fasteners will have to be replaced once you remove them. I would get some speed nut clip and screw fasteners for that.
Thanks for this. Exactly what I needed. The fasteners you're talking about, are they the ones with a small circle in the center of it? Or are they something else. As far as my wheel wells are concerned, all my fasteners are the same type as the one used to secure the tail lights on the sides.
A quick rundown: remove the radiator covers, the belly pans, the wheel well shrouds, and then it's two nuts holding the fascia to the fenders?
If so, then that's fairly easy and straightforward and I thank you again.
Old 05-22-2008, 12:46 AM   #9
Asian Persuasion
Magmania's Avatar
You got it. As for removal of the belly pan (only 1) and the wheel shrouds, you don't have to actually remove them, just the screws and fasteners that attach to the fascia.
I have done this so many times that I can take mine off in like 15 minutes or so.
As for the clips, here is a picture of what I am referring to but other types will work just as well.
Check out this link for some fasteners. You might be able to get these locally in your area but this will show you what some look like.
Auto Body Clips and Fasteners
Magmania's Sig:
Old 05-22-2008, 10:38 PM   #10
3.57MagnuM's Avatar
Just want to say thanks again to magmania for the info on removing the fascia.
I actually removed the clips above the radiator last.
Everything you said though was spot on and my neighbor even freaked out at how fast I got the thing off.
Thanks again.
