Old 05-22-2008, 09:06 AM   #1
11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!11secmagnum is a Magnum Expert!
Send a message via MSN to 11secmagnum
JT Autostyling Lambo doors.... HELP
Hey guys I have a guy that wants to sell me his kit for $400 is this a good deal about a year old. its the JT kit. what do you guys know about this kit? I have heard its pretty good. And who know alot about install because i need to know how you cut the fenders for one. and two the wireing? how do you make it longer or do you need to with this kit. I would like to see up close pictures of this kit on a magnum. Thanks for the help!
11secmagnum is offline   Reply With Quote
Old 05-22-2008, 09:44 AM   #2
krewkut125's Avatar
I dont have the JT kit, I have the VDI but I have played with them at car shows on 300C's and they seem to be a decent kit. Almost everyone will say the VDI and LSD are the two top brands and is what most of us have on here. As for the wiring you should not need to cut it or do anything to it, there is enough in the firewall for extra. Just give them a pull and about 8-10 inches of extra wire will come out.
Old 05-22-2008, 09:49 AM   #3
krewkut125's Avatar
Here are some pics of my kit. Like I said I have the VDI (Vertical Doors Inc.) kit but they should be similar...
You will need to cut these two parts off. Again this is the VDI kit so it may vary a bit with the JT kit.
Hope this helps a little. Jayalberts is the vertical door guy on here so he might chime in later or you could PM him.
Old 05-22-2008, 03:02 PM   #4
thos pictures help ALOT. Did you have to cut your wires or just pull them out??
Old 05-22-2008, 04:27 PM   #5
krewkut125's Avatar
Just pull them out. You have to cut the rubber hose in half then peel it back to get to the clip that holds the wiring harness in. The just simply unclip the harness from the clip and pull the wires out.
Old 05-22-2008, 04:44 PM   #6
Nice thats easy. Whats the Difference between the JT kit and VDI and LSD?? do they open as far?? can you open them normal? Thanks for all the help guys.
Old 05-22-2008, 06:35 PM   #7
krewkut125's Avatar
I know the VDI open 45% of the way (about to the point of where your door has its first "locking" position when opening it. The little pop you hear). I want to say the LSD kit is the same or close but I do not know enough about the JT kit to judge it. The couple of times I played with them they seemed pretty close...
Old 05-23-2008, 04:53 AM   #8
jayalbertcars's Avatar
hello the jt kit is a good kit the only thing that i have seen is that the finish on the jt kit pits and gets rusty looking paint it before you install it
jayalbertcars is online now   Reply With Quote
Old 05-23-2008, 04:54 AM   #9
hello the movement on the door is the same on both the vdi and the jt autostyle kit 2 nights ago juan and i installed 2 vdi kits on a magnum and a charger in around 5 hrs
Old 05-23-2008, 10:34 AM   #10
nice. how easy are they to powder coat?? I might do that.
