OK, What am I missing?
Car should be coming in from CA tomorrow (finally!) and I'm gathering the parts up now. I just realized staring at the front end, there is more missing than I thought. Can you guys identify the missing parts to the front end?
Well your missing a front fascia (obviously, lol), Passenger headlight, you need a new bumper, that foam piece that go's over the bumper, and looks like your missing the AC condenser.
Edit: Also the two black covers over the radiator support under the hood. |
Ok, black covers and foam pieces I can deal with. I can get the bumper for cheap too. but an AC condenser! (sigh) I sure hope not. We'll see when I try to cut it on tomorrow. I noticed on someone else's magnum they had two circular things at the top of the radiator. They looked expensive... I am missing those two items, what are those?
I would replace the bumper cross bar....looks like it was pulled straight....I wouldnt use it.
the AC condensor doesnt look like it is missing. At this point, just install the missing light and the bumper when you get it. That will get that car on the street alteast.... In addition, you will need fog lamps and the brackets, the bottom engine plastic cover and the plastic wheel well covers. You will also need the misc. screws and bolts...not too many. I will include some of the extra screws and nuts I can find. Since I need to upgrade to the SRT bottom cover and wheel wells... I can give mine up when the time comes. Which will be the last week of July..... Last edited by wheelgarage; 06-26-2008 at 04:46 PM.. |
OK, your pic's are a little small but looking at it again on my bigger monitor at work the A/C condenser is there. What I was seeing is the transmission cooler lines on the black A/C consider it looked like they weren't hooked up, but they are. When you get the car I would check the transmission cooler and make sure it isn't beat up, it's that bar right in front of the radiator and A/C condenser.
As far as I know part way threw production on the 07's they stopped using them and none of the 08's have them.
