AH!!!! I got the LED package. If you're gettin that kinda flicker with the stocks then replace the battery. Get a good battery not just a replacement though, since you have plans to add audio. I'd suggest a Kinetic one that fits your budget, those batteries are awesome!
hello i really feel that you both should have the charging system checked i think auto zone does that for free have them check it with no load than recheck it with every thing on. a battery will generally not cause a charge lite to come on also if the battery was bad i feel you would have an issue starting the car so i am not feeling that this is a battery issue
or an Optima Yellow Top for all you guys with tv's,amps,bags,etc.
its worth the price
if its just that circuit, check anything within it. its not daisy chained where if one goes out, they all do... perhaps its a glazed over fuse coming loose or vibrating. always check the simple and free parts first....
the whole thing makes no sense to me man. the flickering/strobing only started after I got the leds, the stocks weren't doin it. so it seems like we have the same issue but.....different...? i'll get the charge system tested I guess
