#21 |
06 Dodge Van Magnum
yup, they haven't gotten any cheaper
#22 |
hello please have the battery and the chargeing system checked first .a quick story that happened to me this past friday i had a mazda mpv van come in with a check engine lite it was a code for the heater in the o2 bank 1 sensor 1. the customer was told it needed to be replaced [by another shop] so i asked if i could check it out first i plug in my modis and all the sensor readings are good includeing the heater readings so i cleared the code and did a drive cycle than when i got back to the shop i decided to chech the fuses as i was checking the fuses with my power probe at first the voltage was 13.9 than all the sudden the voltage dropped to less than 11 volts on all the fuses than the check engine lite came on and it was the heater code again it turned out that the alt. failed when fully loaded at idle the heater needed 12 volts to run the heater the alt is no good we would have put an 02 sensor and still had an issue this is why i would have things checked first
#24 |
Respect My Authoritah!
If you have the LED's you need the led protectors on them..Mine flickered like crazy too..I kept having to replace one here and there from the flickering because it would blow it...The same place I bought my bulbs from sells the led protectors..Have not had one problem since.
LED Flashers Blinkers Resistors Load Equalizers for Turn Signal Replacement Bulbs Rapid Flashing Fix ![]() |
#26 |
If you are running LED bulbs, and are going to the dealer..I would suggest taking them out, so they do not associate that with your problem. If your lights are flickering with just the normal bulbs, then by all means take it to the dealer for a fix.
#28 |
hello dont you know with all this charging and battery talk this morning i went to go out and my battery did not have enought power to start my car i pulled out my midtronics and sure enought by battery was done so now i have a red top optima 1000 cca battery i went to auto zone they hooked me up they know me there i got there best optima battery for under 150.00 i was surprized my factory battery lasted this long with all the add ons i have all running on 1 battery
#29 | |
MOPAR SHOW OFF 2009!!!!!!!!!!!
You guys know you always wanted strobes!!! heres your chance! lol , j/k but it does sound more like your fues or loose wires or you power(batt/alt) Im not expert but id check them out |
#30 |
I just got off the phone with the dealer and they need some help figuring out what the code is that some of you guys or gals have gotten when the reprogram for the light module was done. Anyone have those numbers? It would be on the receipt like 08-012-04.
