back up hood release for those with no external door lock
i wanted to remove the key lock cylinder from my drivers door but was concerned what would happen if the battery died that i would have no way to unlock the door. if i could get the hood open i could atleast jump it to use my keyless remote. so i came up with a cable that is run to the hood latch that you can pull from the inner fender panel. just remove the pins, pull the cable and the hood is open. here are some pics.
![]() i used some 1/16" cable with green jacketing and attached it to the latch, no drilling the holes were already there. ![]() ![]() then i ran the cable thur a series of 3/16" eye bolts (one that i bent 90 degrees) to keep the cable from rudding the headlamp. ![]() ![]() than ran it under the headlamp under the support brace turning the cable back toward thr tire. ![]() ![]() then just put a loop in the cable to act as a pull cord. ![]() hopefully i will never need this but if i do it will be easier then slim jiming the door. if anyone would like one of these kits let me know i can make them and send them to you. i have about $20.00 in parts involved with all the nuts and washers. i am not looking to make any money on these just help out other forum members. |
Thats a really good idea. I got to do this to my Dodge Neon that only has electric door poppers... just in case the batter dies too! THANKS!
thanks guys, i have wanted to do this for awhile now. i have the front fascia off right now installing my water/meth kit and cleaning up some wiring under there and doing a couple of mods to be reported later. so i decided to get this done also
